nos mini programming issue?
same. Channel two is the only channel that will read the tps signal on step 9. How ever when I turn on the nitous the now shows 1 r which I gather means channel two is not active. The channel that I'm hooked up to use.
TEST RPM:
1. You can turn off the TPS input and test the RPM. Test at say 1000, 1200, 1500, 2000, to make sure the right tach signal is there.
TEST TPS:
2. can set RPM very low, say 1 rpm and test the TPS switch.
Just put a bulb, volt meter or something on the +/- connections and make sure your outputs are working. (the red ground from the mini and the + power
from the relay)
If you don't have chan1 TPS hooked up, then how is chan1 activating?
You are going to have to trace all the wires.
