N2O line routing? Inside or outside?
Old Oct 28, 2013 | 10:30 PM
Wicked 94TA's Avatar
I ran my main line today and decided to run it through the inside of the car. It was pretty easy actually. The hardest part was pulling the passenger seat. I have Corbeau's and the back nuts are a PITA to get to. I'm mounting the bottle in the spare tire area. Besides the seat I pulled the passenger side trunk trim piece, the kick panel and the PCM. With all that out it was pretty straight forward and took me less than an hour.
Old Nov 1, 2013 | 11:21 AM
99T/AMAN's Avatar
I think i am going to re-route mine inside the car now after reading this.
Old Nov 1, 2013 | 11:34 AM
speedtigger's Avatar
Old School Heavy
Whenever I see nitrous lines and/or bottles inside the passenger compartment I shudder. All I can think about is a passenger compartment filled with accelerant during a wreck. Yikes.
Old Nov 4, 2013 | 07:04 PM
The bottle is mounted in the spare tire area and the line is under the carpet running along the very edge of the passenger side area. Being in the spare tire compartment I'm not sure a blow down tube is required but I still may install one.
Old Nov 6, 2013 | 06:40 PM
gi8e7oi825's Avatar
What about running it through the rocker panel and over the wheel well, like the a2w lines of the Modular Turbo TT kit (https://ls1tech.com/forums/16393843-post25.html)? Would rubbing be a concern if a bulkhead fitting is used?
Attached Thumbnails N2O line routing?  Inside or outside?-01.jpg   N2O line routing?  Inside or outside?-02.jpg   N2O line routing?  Inside or outside?-03.jpg   N2O line routing?  Inside or outside?-04.jpg
Old Nov 6, 2013 | 08:22 PM
stroked383HSR's Avatar
i routed mine inside..from the spare tire well and down the passenger side thru the firewall.
I got pictures posted on a thread somewhere....you can do a search for it.
Old Nov 6, 2013 | 08:53 PM
boostit5.3's Avatar
i ran mine on the inside because when i first got the car it was slammed on its nuts.. goes from spare tire well across behind the back seat to drivers side under drivers seat through the fire wall right into my solenoid.
