New cam and nitrous ?s
Old Sep 29, 2013 | 07:44 PM
stevecritt's Avatar
Default New cam and nitrous ?s
Should have posted this in here I guess instead of the carb.
http://www.youtube.com/watch?v=TJ2Mz...ature=youtu.be
went from a roll against an ls1 shooting 150 shot with all bolt ons. I'm the camera car.
Now to the questions. I really believe I have too small of a cam for my 408. Just got nitrous, going to shoot a 150 shot, with br7s. What cam lobes are you nitrous guys running? or should I just stick with what I got?
What do you think would be the largest shot I should do with out harming the motor? (wiseco pistons) Forged lunati bottom end.
Thanks for your help.
Old Sep 30, 2013 | 11:55 AM
brandon@nitrousoutlet's Avatar
Without knowing the full specs on the cam I cant tell but from the looks of it the car is pulling hard! A full bolton car with a 150 shot should be in the 500rwhp range and you pulled him pretty good.What kind of RPM are you running? As far as what size shot to run I'd probably start at 150 and work my way up. I don't see there being a problem going 200-250. What Aeromotive pump are you using?
Old Sep 30, 2013 | 02:05 PM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
Do you have the cam specs?
-Garrett
Old Sep 30, 2013 | 03:15 PM
stevecritt's Avatar
cam is in my sig. EPS 234/246 110+2 601/615 lift. I'm ready to swap cams like yesterday, (if You all think I could get a lot more power out of my car with a 150 shot)
stevecritt's Avatar
running to about 7200rpm
Old Sep 30, 2013 | 03:25 PM
speedtigger's Avatar
Old School Heavy
That bad boy sounds good! What is the compression ratio?
Old Sep 30, 2013 | 03:27 PM
stevecritt's Avatar
11.4:1 I'm running 64cc heads and -2 cc wiseco pistons.
Old Sep 30, 2013 | 03:33 PM
Old School Heavy
The compression is the only parameter I would worry about on pump gas. If it were mine, I would throw a 125 shot at it first and see what the plugs look like. I would make sure the fuel system is up to it, install the Br7s, pull 5 degrees of timing and let it eat.
Old Sep 30, 2013 | 03:37 PM
stevecritt's Avatar
Oh I'm running aeromotive SS pump. I called them and they said its good to a 1000 hp with a return regulator. (which I have)
Old Sep 30, 2013 | 03:39 PM
stevecritt's Avatar
Oh I waiting on my plugs to come in tomorrow from summit, and I already have a date with the dyno in Mansfield So I'll know for sure.
Old Sep 30, 2013 | 03:47 PM
stevecritt's Avatar
Too much compression for a bigger shot?
Old School Heavy
Do you have a nitrous kit yet?
Old Sep 30, 2013 | 03:48 PM
stevecritt's Avatar
Yeah I ordered the zex kit, Just looked cool and I don't hear much about them so I thought I would give it a try, if it suck *** then I review it as such.
Old Sep 30, 2013 | 03:52 PM
Old School Heavy
LOL!
I have mostly had NOS kits over the years. I had an old CompuCar kit in the 80s that hit like a sledge hammer, but mostly NOS stuff. I am thinking about "pucking" around with Dave though.
Old Sep 30, 2013 | 03:58 PM
stevecritt's Avatar
"Pucking" what is this you speak of? lol im nitrous newb...
Old Sep 30, 2013 | 04:04 PM
Old School Heavy
You see, when a man and woman are attracted to one another.............
Actually, it is this little gimmick:
http://www.nitrousoutlet.com/nitrous-puck
Old Sep 30, 2013 | 04:07 PM
Brennen's01SS's Avatar
Old Sep 30, 2013 | 04:14 PM
stevecritt's Avatar
now that is some cool shiz. Wonder if it affects airflow when running n/a?
Old Sep 30, 2013 | 04:20 PM
Old School Heavy
I had the same exact question. Dave swears that it doesn't the performance on the motor.
Old Sep 30, 2013 | 04:42 PM
It doesn't. We had an intake flowed with and without and saw no difference.
