Anyone Using The Leash Single Stage Nitrous Board?
Old Mar 21, 2014 | 01:19 PM
My6speedZ's Avatar
Originally Posted by Rise of the Phoenix
Here is what I'm going to do regarding pulling timing: Got this from 03EBZO6
Yes, its just that easy.
I use NOS Mini in this configuration:
Channel 1: Nitrous Noids
Channel 2: EFI COS5
You could in theory put both on Channel 1, but here is why I would not:
As soon as the window is active, COS5 is active. This means you get an immediate spark reduction. HOWEVER, as soon as the window is closed, you also get 100% of the spark back immediately.
So at that instant spark comes back, to keep the nitrous mix/combustion from tangling w/full spark, I add about 200rpm to the window on channel 2.
For example:
Channel 1: 3800-6800
Channel 2: 3800-7000
Your absoluetly on the right track with that line of thought, I'm not sure if you can do this in EFIlive or HPtuners, but I would set your rev-limiter to a spark cut vs a fuel cut, just to further protect yourself during a missed shift or over run.
Old Mar 21, 2014 | 05:10 PM
Petey-Pop-383's Avatar
I just got my Leash Single Stage Board, it's ******* sweet.
You can barley buy the parts for the price of it!
I'll let you know how the install goes, and I am putting mine on the inside of the glove box door of my car.
Old Mar 21, 2014 | 07:45 PM
Rise of the Phoenix's Avatar
Cool, that's great to hear. Post uppics of how you run everything to it and how you mount it to tuck and hide everything. I want mine to look ss clean and factory looking as possible.
Old Mar 22, 2014 | 07:26 AM
mcshocks's Avatar
Originally Posted by My6speedZ
Phoenix I don't know if you picked up that timing twister or not but just so you know the timing twister will not show the correct amount of timing if you are looking at it in HPtuners. The LNC will show the reduced amount of timing when the unit is armed.
According to Lingenfelter this is not true. I called them 3 months ago asking if the timing tables would show the change via the OBDII port and they told me no. According to there tech the only way to see the retard is via the grey output wire from the box. This could be wrong but that's from the horses mouth.
Old Mar 22, 2014 | 07:57 AM
LsoneGT's Avatar
I just purchased one, very nice piece. I have yet to install it due to laziness lol.
Old Mar 22, 2014 | 09:12 AM
You talking about the Leash nitrous board or the LNC?
Old Mar 22, 2014 | 09:28 AM
LsoneGT's Avatar
The leash nitrous board
Old Mar 22, 2014 | 09:44 AM
Make sure to post up pics once you install it.
Old Mar 22, 2014 | 03:34 PM
My6speedZ's Avatar
Funny I was told that if your logging and wire it up to your master arm switch that you can flip the toggle and it will pull the timing and show it in the log.
It plugs into the coil so the engine can see the amount of timing, the Timing Tuner and Timing Twister "trick" the PCM and it still believes its running full timing.
This was told to me from the Nitrous Outlet tech support guys.
Old Mar 23, 2014 | 09:33 AM
greenvortec97's Avatar
I've ran the leash single stage for about a good year now.. I use it with my Trick window switch, Pretty impressive stuff for sure.
Old Mar 23, 2014 | 07:29 PM
JRracing's Avatar
I purchased a leashed single stage board to clean up my current install. I will be wiring this in with a NOS mini controller.
I'm mounting it down on the pass side kick panel in a fox body mustang.
I'll post pics when done.
Old Mar 23, 2014 | 08:05 PM
  #32
I'm going to be using a NOS Mini with mine too. The guys at Leash sent me a wiring diagram.
Old Mar 23, 2014 | 08:13 PM
  #33
mcshocks's Avatar
Yeah LPE said the timing gets manipulated also, I'm assuming there just interrupting the signal going to the coil. Like I said this was from a LPE tech. My original plan was to get a scan gauge that I plug into my OBDII so I could see my WOT timing in front of me. Not a biggy for me as my nitrous controller has a analog input I'll be able to read my timing on but not what I was hoping for.
Old Mar 31, 2014 | 07:38 PM
  #34
LsoneGT's Avatar
[URL=http://s1371.photobucket.com/user/silver992v/media/Mobile%20Uploads/20140330_173601_zpsdfc8c1fe.jpg.html][/URL
Finally got a little time. Not the best pic though
Old Mar 31, 2014 | 08:05 PM
  #35
What other things you got in there aside from the RPM switch? Looks really nice.
Old Apr 1, 2014 | 06:30 AM
  #36
LsoneGT's Avatar
Just a relay for later, and I bought 2 of those strips and made one a ground and the other 12v+. That way I can have a common point and not have wires tapped in all over the place.
Old Apr 1, 2014 | 07:16 AM
  #37
Where did you get those strips at? So on one strip it has a wire that connects to a ground and on the other strip a wire connects to a 12v fused source? Just trying to figure it out in my head as I'm trying to figure out the easiest way to hook up mine. Thanks for the info.
Old Apr 1, 2014 | 07:40 AM
  #38
LsoneGT's Avatar
No problem bro. That's exactly what I did. Home depot has the strips.
Old Apr 1, 2014 | 07:54 AM
  #39
Did you pull the 12v fuse source from the fuse box in the engine compartment or from the fuse panel by the driver's side door?
Also, do most of those wires need to be fused, or are they fused using the relay you got with the nitrous kit?
Old Apr 1, 2014 | 07:59 AM
  #40
LsoneGT's Avatar
They are fused by the wire from the fuse box that feeds it. I had a spare place in my fuse box that I created just for this. I have a ls1 in a mustang so my fuse box may vary from yours, but the same concept should apply
