window switch settings???
Old Apr 14, 2003 | 10:37 PM
1BadAzzWS6's Avatar
Default window switch settings???
Hey fellaz,
Just wanted to get your input on what I should set my window switch at. I have a 2001 T/A WS-6 M6. I bought the 3k and 5k pills for the msd window switch. I have have almost all of the bolt-ons except for headers. I just installed the NOS 5177 kit and the TR-6 plugs. I was at the track 2 weeks ago and was having some serious traction issues, but everyone I talked to said the track always has bad traction issues. I was consistantly trapping at 109, but I was disappointed in my times. I really need to get some drag radials. My best 1/4 time slip was...
R/T .808
60' 2.150
330 5.770
1/8 8.648
MPH 86.12
1000 11.096
1/4 13.165
MPH 109.80
What settings and what shot (I only have the 75, 85, and 100 jets) do you think would help me the most? Any suggestions or input as to what else I need to do or get would be greatly appreciated.
thanx in advance
zack
Old Apr 15, 2003 | 07:33 AM
1MEANSS's Avatar
Default Re: window switch settings???
I have mine set from 3000-6000....
Old Apr 15, 2003 | 08:28 AM
Nitro Dave's Nitrous Outlet's Avatar
Put the 3000 pills and set the shut off right before your rev limiter.A larger shot will just hurt you.Get some slicks or drag radials.Then up the shot.Your 60 foot is killing you.
Dave
Old Apr 19, 2003 | 03:47 AM
1BadAzzWS6's Avatar
ok, so I'll set it to come on at 3000 and... if I am shifting at 5900-6000, then I should set it at 5800??? I'm just not clear on where to set it to go off at.
Old Apr 19, 2003 | 05:10 AM
2002_TAWS6's Avatar
what big of a shot are u using? im not a hater but 13.1s with nitrous? <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old Apr 19, 2003 | 05:50 AM
Orange Krush's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by PizzOnFord:
<strong> ok, so I'll set it to come on at 3000 and... if I am shifting at 5900-6000, then I should set it at 5800??? I'm just not clear on where to set it to go off at. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I have my A4 set to spray between 3000 r.p.m. and 6000 r.p.m. my Z shifts @ 6200! <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old Apr 19, 2003 | 06:51 AM
1BadAzzWS6's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 2002_TAWS6:
<strong> what big of a shot are u using? im not a hater but 13.1s with nitrous? <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That was N/A. I haven't run with the NOS yet. I was trying to figure out which pills to use before I f*** something up. I have the 75, 85, and 100 jets. I have the 3000 and 5000 sets of pills. I am defiantely going to have it come on at 3000 and I'm just not sure what to have it off at. I am not even going to turn it on till 3rd gear.
Old Apr 19, 2003 | 03:13 PM
WS6 GreeN's Avatar
It doesn't matter. You just don't want it to be on when you shift. Put your 5K pill in. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<small>[ April 19, 2003, 03:16 PM: Message edited by: WS6 GreeN ]</small>
Old Apr 20, 2003 | 11:36 AM
LASTLS1's Avatar
6 Second Club Moderator
Turn it on at 3400 off at 5800. go 100 out of the box unless your running very lean. ie after market mass air flow. If you have a stock mass air flow take out the screen. You will be fine. If you installed a fuel pressure safty switch you might have to adjust it, I did. It kept turning on a off. I took it out and bought a guage. Also you can spray in first gear just don't floor it until you get rolling. Good luck!
Old Apr 21, 2003 | 09:08 AM
1MEANSS's Avatar
Have it kick off at 6000, your stock rev limiter is 6200 so you'll be all good <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
