NX MAF results
Old May 17, 2014 | 01:09 PM
jblankenship's Avatar
Default NX MAF results
Finally got a clean pass on the NX MAF plate. I made a hit last week to the 1/8 on .044/.024 on both stages. First stage was set to 0 delay, 30% start, build to 1.0. Second stage turned on 100% at 1.0. Ran a lazy 6.76. I say lazy because it felt much smoother than my nozzles had. I did leave in the kids car seats and floor mats on this pass.
Last night I pulled out the floor mats, kids seats, and junk in the back like normal.
15 PSI cold in the MTs
18 degrees total timing
B8efs plugs at .030
First stage was .047/.024, 0 delay, 30% start, .6 build
Second stage was .053/.028, 100% on at .7
DA: 571
60: 1.4698
330: 4.2191
1/8: 6.5558
mph: 106.46
1/4: 10.2867
mph: 129.35
Attached Thumbnails NX MAF results-new-nitrous.jpg   NX MAF results-nitrous-switch.jpg
Old May 17, 2014 | 02:33 PM
Bad Habit Bird's Avatar
I do love the NX MAF kit.
Old May 18, 2014 | 10:47 AM
slvr T/A's Avatar
Very nice times. 4L60E?
Old May 18, 2014 | 12:42 PM
Yes 4l60e with hd2 kit and deep truck pan. 10 bolt too.
Old May 18, 2014 | 05:27 PM
slvr T/A's Avatar
Does it run out of gear in the 1/4 with those 3.73s?
Old May 18, 2014 | 06:38 PM
No its about perfect. 3rd gear is topped.
Old May 22, 2014 | 07:09 AM
Dynospeed's Avatar
Nice times man. Work on leaving with more % on the hit. It all depends on you suspension and tire. I also saw you are still on a 10 bolt so maybe you don't want to. Lol
Old May 22, 2014 | 08:33 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
Good times! Let me know if you need anything else on our end.
-Garrett
Old May 22, 2014 | 01:00 PM
Thanks. Already turned the build time down and the upper window higher.
Old May 22, 2014 | 05:39 PM
BSmiff's Avatar
Sounds like that thing is truckin right along boss. Simple *** combo running a big number.
Old May 22, 2014 | 09:00 PM
Thanks for the compliments guys. Stuck an .053 jet in the first stage as well. Going to tune this setup and let it be.
