nitrous issues
This winter we added a Nitrous Outlet wet plate kit with a NANO system and all the bells and whistles. On the dyno, with 100 jets, it make 502 rwhp (130 over NA) and has a safe AFR number and the timing mark on the plugs was perfect.
However ... at the track the car only ran a best of 11.40. ??? Nitrous and NANO bottle were full, pressure was fine, purged a steady stream of nitrous, plug straps weren't chewed up or missing after the run. With over 500 to the wheels this car should have been solidly in the 10s.
We run a Yank SS4000 and a stock 4L60E. Is it blowing through the converter and/or the transmission slipping and if so on either would that kill the ET that much? I'll attach a copy of a NA run and nitrous run from HP Tuners. We're new to that program so if I need to attach something else or email a copy to someone walk me through what you need as we would appreciate another set of eyes looking at it.
Thanks!
Scott
Scott
I do believe the system hit by looking at the scan and also from feel. It blew the tires off instantly. I think after that the transmission never shifted correctly and was "goofy" the whole run.
I'm putting a progressive controller on it this week to see if I can wait a second or so to hit it and then see what the ETs look like. I always have the option of tuning it on instantly still once I get it all figured out. Still waiting on my tuner to look at the scan to see if the transmission operated properly.
I would spray out the hole as well. No need for a progressive with that baby shot, unless you plan on upping the jets a lot bigger in the future.
I'm going to go ahead and put a progressive controller on there just to start small and work up. I need to be able to scan runs and see what's going on with shift points on the nitrous and when it blows the tires off so violently on the launch IMHO it messes up the rest of the run and scan. After I can see what's going on I can turn the progressive controller off and hit it out of the hole. Plus, when we run at tracks with suspect starting lines I'll have the ability to take a little out of it. We do also plan to go forged later and add a second stage with more nitrous so this will give us the ability to tune it later.
Thanks!
Scott
