HCI Ls1 Nitrous Dyno
I have a 2002 M6 TA with 35k miles on the clock. My old dyno #s before i swapped to 3.90 gears and to Br7 plugs were 453/413 to the wheels. The motor tnite put down 423/403 to the wheels... Thought it was kind of odd that I lost that much power, but it hauls *** on the motor as is... Anyways, below are my mods.
Stock bottom end Ls1
T56 Monster Level 2
AI 226cc Ls6 heads 63cc chambers
.040 gaskets 11.1:1 compression
Tv2 cam
FAST 92/92
TSP 1 3/4 Lts, ORY, Slp exhaust
3.90 gears
Racetronix 255 Pump with hotwire
Water injection
Dynotune nozzle wet kit
1000psi bottle pressure
Window switch 3000-6200
91 pump gas
We started with the recommended 150 jetting from Dynotune but it only yielded 105 to the wheels with 5* pulled. After a few jet swaps we ended up running a 70N/40F jet set up and pulling 9* which according to the calculator is good for around a 220 shot... Whats interesting is that the HP and TQ made exactly the same peak power... Any thoughts on this? Overall im very pleased with the numbers and the AFR was very safe in the 11.2-11.5 range.
572WHP 572WTQ
This gives me some motivation to stick to adding nitrous to my car over winter. Been thinking about selling off all my n/a stuff and going turbo. But I just don't want to yet.
That is the kit on my car. I also upgraded to their larger .091 orifice nitrous solenoid in order to run 150+... We were all kind of wondering if the lines or nozzle had reached their limit because we went from a 62N jet to the 70N and only picked up 10whp...
They are sending me out a -4AN line to test with and see if it picks up power.
-Garrett
That is pretty funny that it made the same exact hp/tq numbers!
-Garrett
T56 Monster Level 2
Tv2 cam
FAST 92/92
3.90 gears
Water injection
91 pump gas
572WHP 572WTQ
I would also go to a #8 plug.
Pulling 9* from what total ?
I have a 1968 GTO running a 350 shot and the AFR is 12.5 as is the NA tune.. But it is also a dedicated nitrous motor... So it was a bit hard to go leaner on my daily driver...
Seems to me everyone is always super aggressive with timing but scared to death of a lean A/F ratio.
I'd much rather run any car even my DD at 12.5 A/F and soft on timing then 11.5 and aggressive with timing.
That is JMO.
I would get some #8 plugs and start tuning at the track by the plugs.
Dyno wont show you a true timing mark and usually the A/F is off alittle because the load is not the same.
Good luck.
That is JMO.
Good luck.
I'm surprised the 2 is holding that, as it's exceeded at that level, and Monster doesn't even recommend a 2 for nitrous. Just curious. I loved mine, but wasn't running a shot either.
The dyno software has a slip% function and it detected zero slip on the runs... So all is good (for now)
