Help nitrious guys
Old Oct 19, 2014 | 08:32 PM
sbf's Avatar
sbf
Default Help nitrious guys
I have a 408 l92 intake nitrious outlet spray nozzle in front of throttle body.have a stand alone 112 for nos.okay sprayed today for first time 150 felt like a 25 shot barely pick up .10 psi fuel pressure 6 degrees of timing pulled with lcn-2000.and some old nitrious works solenoid.do y'all think the noids is the problem they both click when activated but I think a 150 should hit way harder well it sure did on my old school 406 with plate
Old Oct 21, 2014 | 05:26 PM
AJatNitrousOutlet's Avatar
Do you have a purge? You may have alot of air in the lines-
Old Oct 21, 2014 | 06:08 PM
00FirebirdaREV's Avatar
I would check solenoids and also check for leaks between solenoid and nozzle. Do you have a window switch? Are you sure it was in working order?
Old Oct 21, 2014 | 06:09 PM
sbf's Avatar
sbf
No I don't have a purge I just bleed it the old school way,crack the line till nos come out
Old Oct 21, 2014 | 07:00 PM
phoenix rises's Avatar
do you have a bottle warmer and pressure gauge?
Old Oct 21, 2014 | 07:25 PM
sbf's Avatar
sbf
Bottle pressure was 950
Old Oct 22, 2014 | 08:35 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
Do you know the orifice size of the solenoids?
-Garrett
Old Oct 22, 2014 | 09:40 AM
brandon@nitrousoutlet's Avatar
what jets are in the nozzle?
Old Oct 22, 2014 | 06:07 PM
sbf's Avatar
sbf
I forgot what jets but don't no orfice size they are old school nitrious works solenoid
