Nitrous compression ratio
Old Dec 24, 2014 | 08:31 PM
loosews6's Avatar
Default Nitrous compression ratio
I'm freshening up my 408 going with ls3 trick flows 255s heads from Frankenstein racing, I'm going with the holley system this time, senting my 4500 flange ls3 super Victor to Jeff prock@ applied nitrous to do a single stage dry set up. Plan to spray 450hp max going to start around 300 hp.. car will be around 3100 race weight... going to run vp c23 race gas.. What compression ratio will be good also this is a track only car..
Old Dec 25, 2014 | 06:54 AM
WE TODD DID's Avatar
As much as you can get.... Be sure to tell your cylinder head guy to make the chambers right.
Old Dec 25, 2014 | 08:06 AM
loosews6's Avatar
Yea going to run at least a 0.60 gasket just trying to see what compression ratio was thinking around 12. 1 or 13.1 what would we the hp different in the too? Because they head are 69cc now
Old Feb 24, 2015 | 08:35 PM
loosews6's Avatar
Bump for more info
Old Feb 25, 2015 | 02:25 AM
toby's Avatar
i would shoot for 13.1. get the quench between .080-.1 with that much nitrous.
Old Feb 25, 2015 | 08:15 AM
Dynospeed's Avatar
With c23 you can get away with alot of compression but like always the tune has to be on point. If your not jet limited I would run 13.1-14.1. I tune a LS motor with 15.8 compression that is jet limited. When it was flowing 200-225 it was pretty easy. Once we started freezing the nitrous and pushing it which had it consuming roughly 400 worth of nitrous she got very timing sensitive. Are you going solid roller?
Old Feb 25, 2015 | 08:24 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
This. Higher compression setups have a narrowed tuning window, especially on bigger jets. (Less margin of error.) I think 13:1 - 14:1 would be best suited for what your goals are.
Thanks,
Garrett
Old Feb 26, 2015 | 07:23 PM
loosews6's Avatar
Hydraulic roller... think around 12.5 to 13.1
