nos mini progressive with 2 step
I'm about to wire up my progressive controller tomorrow and how do I wire in the 2step so that when I'm on the 2 step the nitrous won't activate? Do I need to run relays? I've heard there are relays already in the nos mini? New to nitrous and not really sure. Rest of the wiring looks pretty straightforward
I could. But let's say I want 4k on the 2 step to launch. The nitrous would probably kick in around 3k. There was a photo in a thread that showed a trans brake which should be the same. The link is dead to the photo
Call Brandon at Nitrous Outlet. Although we don't have the exact same situation as you when I had wiring questions I would call him and would shoot me an email with the diagrams. Extremely helpful and has forgotten more about nitrous wiring that I'll ever know.
Scott
Scott
I may be wrong but I think that I wired my trans brake on a relay, then ran the normally closed contact off of the realy to the feed to the WOT switch. When the relay is not energized the The signal passes through to the WOT switch un interupted. The the Brake button is pushed the signal to WOT is interupted.
