Standalone Fuel
Old May 10, 2015 | 04:45 PM
Bama99z's Avatar
Default Standalone Fuel
Needing info on fuel to run in my standalone fuel cell.
Old May 11, 2015 | 08:20 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
We normally run race fuel in them, you could also run e85! If you are wanting to run methanol you will need to change some things up in the nitrous system. If you have anymore questions ask away!
Thanks,
Garrett
Old May 11, 2015 | 09:15 AM
Nitro Dave's Nitrous Outlet's Avatar
In all my gas applications I usually run C-16 in the dedicated. What does your combo consist of?
Old May 11, 2015 | 09:51 AM
Any kind of race fuel will be fine for use in the dedicated. Anything from 105-120octane is preferred. Personally I'd suggest using C16 in the dedicated. Even though it's a leaded fuel the amount used won't hurt the 02's of the car.
SPECIFICATION SHEET FOR C-16
(Typical Values) Specific Gravity: .735 @ 60°F
Lead: Yes
Color: Blue
Motor Octane: 117
Reid Vapor Pressure: 1.85
Oxidation Stability (min.) 1440+
Distillation:
10% evap @ 211.5°F
50% evap @ 213.1°F
90% evap @ 215.8°F
E.P. @ 233.3°F
Production: Elmendorf, Texas USA
Availability: Sealed Drums
Rev: 07/00
-Chris
Old May 11, 2015 | 05:31 PM
dekan513's Avatar
i was gonna use c-16 but couldnt find none local before i went racing . ended up finding 112 sunoco and its seems decent. anything is better then the **** 93 we have.
Old May 11, 2015 | 08:58 PM
Bama99z's Avatar
Thanks for the suggestions guys. I actually spoke with Brandon @ Nitrous Outlet today. I was wanting to go with VP C16, however the closest that I can find around me is at least a 1 1/2 hour away, so I have decided to go with the Renegade Equivelent.
Old May 12, 2015 | 07:51 AM
That will be fine. I just use C-16 because its easy to get here locally.
Old May 12, 2015 | 09:02 AM
You'll be just fine with the Renegade fuel. I know lots of customers that have been very happy using their brand.
-Chris
