C5 nitrous feed line routing
'Bout time I finish off my nitrous install.... What's the best/easiest route to get the feed line from the trunk on a C5 vert to the engine compartment...any pics?
Thx!
Thx!
Ls1tech & Truck Sponsor
No pics, but I'd run it down the passenger side in the vehicle and up through the firewall. You'll need to take the battery out and the kick panel in the car out, but there should be a flat area that you will need to drill a hole for the feed line. This is where I've seen most run the lines.
-Chris
-Chris
Good question. We didn't. Ran in under the car on the passenger side and used coated fuel line "attachers" with self-tapping screws to keep it up. Have never had a problem and I like it being outside of the car. Don't know if it would ever make a difference.
Scott
Scott
Did mine as per mcshocks..... Remove front and rear wheel well liners, from the truck down along inside the rocker and into the engine compartment.... Easy, no issues, not inside the passenger compartment
