Rev limiter using Nitrous
Old Aug 18, 2016 | 05:59 PM
dw456post's Avatar
Default Rev limiter using Nitrous
How do you guys set up the rev limiter control in the tune? Control by fuel or spark or none?
Old Aug 18, 2016 | 06:03 PM
HCI2000SS's Avatar
You want your rev limiter for nitrous to be different than when it's off nitrous, or am I misunderstanding?
Old Aug 18, 2016 | 07:07 PM
dw456post's Avatar
That's right. What is the correct way to set it for Nitrous?
In my E40, there is Fuel---enabled/disabled, Spark---enabled/disabled, ETC---enabled/disabled to choose from. Stock limiter is Fuel---Enabled.
Thanks
Old Aug 18, 2016 | 07:12 PM
HCI2000SS's Avatar
Honestly I've never heard of a dual rev limiter for our cars. Sure you're not referring to the window switch which controls the rpm in which you can spray in?
Old Aug 18, 2016 | 07:34 PM
dw456post's Avatar
No, If you open HPTuners and go to the rev limiter tab, there are 3 choices in which to limit rpm. Spark, Fuel or ETC.
I guess the window switch would eliminate the rev limit worry.
Old Aug 18, 2016 | 07:37 PM
HCI2000SS's Avatar
Ok I was not familiar with that. But yes set the window switch maybe 300 rpm before the limiter and there's no real need for this
Old Aug 18, 2016 | 07:48 PM
dw456post's Avatar
Thanks!
Old Aug 21, 2016 | 08:14 AM
redgto4u's Avatar
The e40 will not enable spark cut to my knowledge. Most people use the lnc2000 and/or a window switch to kill the nitrous before you hit the limiter.
