any way to hide direct port system?
and a dry kit..
well i have the SLP 85mm MAF
which we all know is incompetent of even running the car n/a
so i really dont want to let it have anything to do with metering n2o
and deciding how much fuel to add.
that leaves, direct port, right?
is there ANY way to hide DP?
i know for SBC there is an under manifold setup,
what about these cars?
can i put corvette fuel rail covers on to hide direct port?
(it would be a good excuse to get vette rail covers, too)
to answer your question, i saw one time a VERY VERY trick DP system, it used hard lines that were bent INSIDE the manifold. the kit was not hidden completely, but if you were to put some frc's on that motor it would have been one sneaky sumbitch
how big of a shot are you running? direct port is usually used for pretty large shots, the smallest ive seen is 150. if you want to play it safe, put the stock maf back in and get a dry shot
j/k Trending Topics
Just install it and go racing, hiding **** is really stupid, only works on 16year old ricer want-to-be's.
SDB
SDB
If I could hide it, I would. I like the look of a clean engine bay.
