Plug read help.. 175 shot 9.19 et
Old Sep 30, 2017 | 11:32 PM
foose04's Avatar
Default Plug read help.. 175 shot 9.19 et
Still getting a handle on this. Would I be correct in thinking the mark is at the bottom of the strap or is it actually toward the tip? Car was started before burnout box and run till end of 1/4 and shut off.
C16 fuel and NGK 9 heat range
125 shot on first slip with 7 degrees pulled, 29 base.
175 shot on second slip with 13 pulled, 29 base.
Was about 60 outside and cloudy.
Will post video shortly, thanks guys.
Updated with vid.
Attached Thumbnails Plug read help.. 175 shot 9.19 et-img_1414.jpg   Plug read help.. 175 shot 9.19 et-img_1416.jpg   Plug read help.. 175 shot 9.19 et-img_1418.jpg   Plug read help.. 175 shot 9.19 et-img_1419.jpg   Plug read help.. 175 shot 9.19 et-img_1420.jpg
Old Oct 1, 2017 | 01:15 PM
baronsmith98's Avatar
For some reason the picture is a little blurry on my phone but the 1st picture of the plug the timing mark looks like it is toward the tip. What is the motor setup? Nice timeslip
Old Oct 1, 2017 | 01:31 PM
foose04's Avatar
Thanks man. As for the pic, it's weird. If you click and hold to open them in a new window it's high resolution.
Ls2 404, tf 235s, solid roller nitrous cam. 13.5 to 1 compression.
Old Oct 1, 2017 | 03:39 PM
I have seen videos of your truck too it runs really good. I see you're in charleston too. We have a race going on October 21st called Truck Wars 2 in Jeffersonville,GA at Middle Georgia Motorsports Park. It's a fun race with everything from street trucks to low 4 second trucks. You should bring yours out if you have the time. That mustang you have is rolling pretty good.
Old Oct 1, 2017 | 09:18 PM
pantera_efi's Avatar
Default Perfect Read
Hi Chip, I would STATE "perfect".
Lance
Old Oct 2, 2017 | 01:30 PM
speedtigger's Avatar
Old School Heavy
I don't see any heat in the plug. You have pulled 13 degrees 0n C16 for a 175 shot. That is very conservative and that is likely why you have no discernable timing mark on the electrode.
As for the fuel mixture, there is no way to tell from the pictures that you have supplied. You need to be able to see the fuel ring area of the porcelain which is not visible in your pictures.
This picture shows where to look for the "fuel ring" on the spark plug:
In this area you want to see a faint, barely visible fuel ring. To do this properly, you need to install brand new plugs, push it to the line, make 1 pass and shut it off immediately after the pass. Either pull the plugs on the return road or tow back to the pits and pull them. No idle time after the pass if you want an accurate assessment.
Old Oct 2, 2017 | 01:56 PM
AnotherWs6's Avatar
One of those slips says you made a 9 second pass at 21 mph, WTF?
Old Oct 2, 2017 | 08:17 PM
foose04's Avatar
Thanks man, I'm actually in North Dakota right now lol (military life) I wish I could make the truck wars though.
Hey thanks for the input, i've read pretty much all your post and appreciate the info. I know it's a lot of timing to be pulled, I honestly didn't think it needed that much but had a local nitrous guy telling me to pull like crazy and add back. Between 13.5/1 compression and a 60 degree day, I just wanted to get a starting point. That said, the last small tire event is next weekend in Stugis and i'd like to try my hand at making a couple rounds. I figure I need a 5.5x car to make it a couple rounds, track is 3000ft above sea level and I hope the cold track will give the big power cars issues. I figure a 1.2x-1.3x and about 200-225 jet will be my ticket. I have all Friday to test, Saturday is shootout.
Ive got fresh stiff wall slicks to try out to replace the radial slicks. I know the radial slicks will be faster, but with it being so cold out I need all the bite I can get.
The track has a serious issue with leafs in the fall, always messing up something on the timeslip. Sucks.
Old Oct 4, 2017 | 10:47 AM
brandon@nitrousoutlet's Avatar
First off, car looks great! It sounded a little flat and that's probably due to the amount of timing pulled. As Speedtigger stated, there isn't any heat on the plug and no discernible timing mark. I can't see the fuel ring on the plug. You have a good starting point to get the Air/Fuel sorted out. Once you get the fuel close, you can start adding timing back. Watch the plug as you're giving it timing because it can change the fueling(more efficient burn). Sometimes as you give it timing, it can want a little more fuel. Just have to watch the slip as you make changes. You might consider putting an 8 heat range plug in it for these horsepower settings(up to about 250).
Old Oct 4, 2017 | 11:42 AM
Default Jerry Grant = Spark Plug Tech
Hi Chip, I was taught to "read" Spark Plugs by Jerry Grant, an INDY 500 winner AND the Champion Spark Plug chief "tech".
What I state STANDS.
What I do not see is the Spark Plug Heat Range "fire band" in your pictures.
Could you post a picture of the Insulator inside the plug steel ?
I would NOT add Spark Advance at this time.
Lance
Old Oct 5, 2017 | 01:39 PM
LSX Power Tuning's Avatar
Agree 100%.
Old Oct 8, 2017 | 12:26 AM
blk00ss's Avatar
Can someone please stop Lance from “reading” plugs in the Nitrous section. Indy car spark plugs have zero to do with a Nitrous car.
Old Oct 8, 2017 | 09:48 AM
Hi 00ass, NO !
I work with Mike Thermos, Nitrous Supply, he AGREES with MY READ.
Mike INVENTED Modern NOS AND created Nitrous Oxide Systems.
He too agrees that ignition in a N02 injected engine is VERY important AND thus fits my IGN-1A coils when required.
He states with a strong ignition, he often sees a DROP in EGT when "sprayed"
Most here state "Add Timing" which is VERY dangerous AND will destroy the engine when too great.
I state add Ignition Energy by Coil Dwell increase or Stronger Coil Fitment.
The "song" of an engine will be better with the correct Spark Instant and Quality Ignition.
I "read" Crankshaft Acceleration, easy with the 58x TW, finding the EXACT BEST Spark instant.
MY opinion is that this is a thing YOU have NEVER done !
Lance
Old Oct 8, 2017 | 03:26 PM
blk00ss's Avatar
Whatever. All you’re here to do is push your ******* cool packs. That’s the only thing you ever say. Take your broken English *** out of here.
Old Oct 8, 2017 | 08:27 PM
Default Truth In Statements = POOR Modders
HI ALL, BECAUSE I STATE TRUE, I GET MODDED/OR OTHERS WHO POST ILLEGAL WORDS = NOT.
NOW YOU HAVE POWER, (BLKOOSS) FOR FREE !
Many here will spend good money to buy AFR meters, test equipment, etc. to find the cause of a problem.
The ROOT cause is often a weak spark !
Thanks, BLKOOSS My Friend + 10% commission !
Lance
Old Oct 8, 2017 | 11:50 PM
blk00ss's Avatar
Drugs are bad mmk.
Old Oct 9, 2017 | 03:58 PM
MY_2K_Z's Avatar
Originally Posted by blk00ss
Drugs are bad mmk.
Lmao I was think the same
Old Oct 10, 2017 | 01:18 AM
foose04's Avatar
Default Update: more bottle
still at it, went to Sturgis SD 1/8 mile for small tire shootout. Got a bunch of testing in but learned 3400ft track elevation is no joke. DA was over 4500 for the day. That said got some new best. 200 shot with 9 degrees pulled went 5.69. 225 shot with 11 pulled went 5.58@123, 1.25 60. Best 60 of the day was 1.24. Only changed since last video was more timing, anti roll bar setting change, 28x10.50 stiff wall m/t's. Leaving at 3000 rpm 2-step 40% progressive ramping 100% at 1.1 on 200, 1.3 on 225. Still on straight C16.
200
First 225
Adjusted front end limiters and shocks, slowed ramp from 1.1 sec to 1.3. 225 shot
Attached Thumbnails Plug read help.. 175 shot 9.19 et-img_1504.jpg   Plug read help.. 175 shot 9.19 et-img_1505.jpg
Old Oct 10, 2017 | 01:40 AM
blk00ss's Avatar
That’s awesome man. I was wondering where that car went. I seriously contimplated buying it at one point. Looked like an awesome build.
Old Oct 12, 2017 | 08:43 PM
JoeNova's Avatar
Restricted User
Lance most likely has more automotive knowledge than anyone on this forum, having done engineering work for more major manufacturers than you can spell, and has been involved in R&D work for more types of racing and powersports than you've ever spectated.
Don't be an *******. As far as I'm concerned, his words are gold.
