200 shot stock
Old Aug 7, 2018 | 09:27 AM
98cherrySS's Avatar
Wouldn't stock ring gaps be a concern here?
Old Aug 7, 2018 | 09:30 AM
Lpina650's Avatar
yes, I'm pushing it hard but I don't expect this to last forever. I will build a motor after this
Old Aug 7, 2018 | 09:34 AM
dckmn52's Avatar
More a connecting rod issue than anything. A good tuneup on the stock rings will go a long way. This has been proven on SBE combos plenty of times.
The problem isnt just that people lean out the mix either, its that they run way rich too. Washing the cylinder walls down can be just as bad as running lean.
Old Aug 7, 2018 | 09:37 AM
98cherrySS's Avatar
How many passes have you made at 250? Plate or direct?
Old Aug 7, 2018 | 11:26 AM
98redorangeta's Avatar
https://ls1tech.com/forums/nitrous-o...rous-list.html
all the blue names on the list are sbe the bottom end can do a 200 shot no problem if you have good fuel and tune the correct plugs and a decent plate.
Old Aug 7, 2018 | 02:42 PM
ragtopz28's Avatar
Just a measly 150 shot on a SBE 6.0
I'm gonna try for a 5.999 on a 200 (with a few other tweaks of course).
Old Aug 7, 2018 | 03:58 PM
Jtm2085's Avatar
What gear and tire are you running ragtop?
Old Aug 7, 2018 | 04:13 PM
ragtopz28's Avatar
3.54 in a Dana60, 4L60, on a 26" radial slick.
Old Aug 8, 2018 | 06:44 PM
'68LT1camaro's Avatar
Originally Posted by svt_z06
Will a stock Ls6 motor take a 200 shot? Of course, I plan on reducing the timing and upping the fuel, cold plugs, br8ef or br7ef. I have the fuel for it. Currently on an E45 mix. Looking to get into the 6s in the 1/8th.
Thanks!!!
Short answer, yes.
Not so short answer, I will only give advice for 200-300 shots with fuels I have used at those power levels. I don't recommend using ethanol with nitrous. To clarify, this is not based on any negative experience I have personally had with ethanol. It's because of a conversation I had about fuels with Monte Smith (god rest his soul). I won't go into anymore detail than that. My personal advice, I recommend you do a direct port set up with a stand alone fuel cell. For a 200-250 shot, you need B8EFS plugs (no such thing as BR8EF plugs) gapped at .028 with VP NO2 or VP C23. For a 300 shot, do B9EFS plugs gapped at .026 and C23 in the stand alone. Pull 3 degrees of timing per 50 shot (Yes, that's 12 degrees pulled out at 200) and then work the timing back in slowly. If you want to play it safe like I do, don't go all the way into the the bend with your timing mark.
Good luck.
Old Aug 8, 2018 | 07:44 PM
svt_z06's Avatar
Originally Posted by '68LT1camaro
Short answer, yes.
Good luck.
Outstanding. Thanks so much for your time!
