Proton plus nitrous noid orifice size?
Old 08-16-2018, 10:59 PM
Dano 00TA's Avatar
Default Proton plus nitrous noid orifice size?
My NX Proton Plus nitrous solenoid got something in it to cause it to stick open (luckily I noticed while not running) I took it apart and cleaned it but apparently the debris messed up the teflon seal and it still has a tine leak. Unfortunately however there's no part number on the noid for me to go by to get a rebuild kit. If I even knew the orifice size then I can get one. I know this is a longshot and I did message NX about it but figured if anyone knew here it'd save me some time. Thanks
Old 08-16-2018, 11:23 PM
Received 3,022 Likes on 2,353 Posts
Is the kit Mfr. still in business? If so try to contact them. They would know more than anyone here.
Old 08-16-2018, 11:35 PM
Dano 00TA's Avatar
Oh yeah, it's a Nitrous Express kit. I did send them a message through their Facebook page. I guess I can try to call them also tomorrow. I wish they'd put part numbers on the noids though....I have another older noid that also leaks and has no part number either.
Old 08-16-2018, 11:38 PM
I would look up their phone # and actually talk with someone.
Old 08-16-2018, 11:47 PM
Dano 00TA's Avatar
That probably would be the quickest way. Will do it in the morning. Thanks
Old 08-17-2018, 03:56 AM
HCI2000SS's Avatar
Other than the issue, how do you like the Proton kit? I have a NX single nozzle wet kit myself. Kit is at 15 years old, and never had an issue
Old 08-17-2018, 10:55 AM
Dano 00TA's Avatar
Other than this, I liked the kit. Had no issues with it and liked how compact it is.
Old 08-17-2018, 10:56 AM
Dano 00TA's Avatar
Found out that they don't sell rebuild kits for it and it has to be sent in for them to rebuild
Old 08-17-2018, 08:58 PM
'68LT1camaro's Avatar
Did they quote you a price for the rebuild?
Old 08-18-2018, 12:57 PM
Dano 00TA's Avatar
[QUOTE='68LT1camaro;19951091]Did they quote you a price for the rebuild?[/QUOTE
60 bucks for testing/rebuild per solenoid.
Old 08-21-2018, 02:54 PM
Skizzy's Avatar
The nitrous noid in the Proton kit is .078 which is similar to the NX mainline series of noid.
The fuel should be fine and if it was clicking under pressure prior to removal then the coil should be ok also. With it leaking as you described it sounds like just the nitrous piston needs to be changed out.
-Chris
Old 08-21-2018, 03:23 PM
Dano 00TA's Avatar
-Chris
Yeah, I ended up taking the module apart and found the nitrous solenoid had a pretty big piece of rubber in it? I have no idea where it came from cause I've used it a couple times on the same bottle. (no lines were removed) but I'm gonna run a filter for now on. Was told to send in a pic of the bad piston which I did. Hopefully they'll just sell me a new piston. Thanks for the size however.
Old 08-21-2018, 07:06 PM
That's cheap. Just send it in. That's the simplest, cheapest route to getting you up and running again.
Old 08-21-2018, 07:15 PM
Yeah, I ended up taking the module apart and found the nitrous solenoid had a pretty big piece of rubber in it? Hopefully they'll just sell me a new piston.
.........just saw this.........
Can you post a pic of the "pretty big piece of rubber" and the plunger?
Old 08-21-2018, 08:08 PM
Dano 00TA's Avatar
Rubber is gone but here's the plunger Can't see from this pic but it left a pretty good indent in the teflon. Like I said, I have 0 ideas on where it came from.
Old 08-21-2018, 08:10 PM
Dano 00TA's Avatar
Already have it apart, so he said to send him a pic of the plunger/piston. I had another set of Iceman solenoids I'm gonna run now. Maybe just keep this setup as backup.
