What do you use to retard your timing?
Old Aug 25, 2004 | 08:26 PM
DEEZ98Z's Avatar
Default What do you use to retard your timing?
I was looking into getting a timing tuner, so I can still run my car with the N/A tune on the street. I dont really want to have to put in two different tunes every time that I run the nitrous. How are you guys doing this? Any help and suggestions would be great!
Wes
Old Aug 26, 2004 | 08:30 AM
LS1M's Avatar
You can put a resistor where the IAT goes to trick the computer into thinking the air is real hot, and it'll retard timing accordingly. Only a couple of degrees, though. Or, if you're going to tune it with ls1edit or hp tuners, you could adjust the timing tables for that intake temperature & use a relay on it, so when you spray the resistor switches in, the IAT shoots up and the computer uses the timing you put in the table for that temp range.
Old Aug 26, 2004 | 08:55 AM
jimmyblue's Avatar
Moderator
I told my buddy to do that (resistor + relay off the 'noid)
and he got the timing pull he was looking for. He had the
IAT reading at 140F on the TechII.
Old Aug 26, 2004 | 08:58 AM
c5ls1vette's Avatar
Get the Ramchargers timing tuner it works great. It plugs into the crank sensor.
Do a search on the timing tuner and you will get alot of information.
Old Aug 26, 2004 | 10:42 AM
marlowchris's Avatar
Call Nitro Dave and get a timing tuner. Mine works great!
Old Aug 26, 2004 | 10:47 AM
horist's Avatar
I haven't tested this yet since I have sprayed this year yet... but I believe this should work... (requires HPT or some PCM editing software)
for low IAT values I just pull timing... since I don't drive the car in the winter/really cold weather should work fine
but the resistor mod should work fine too on a stock PCM w/out editing ... looks like 122* or higher it pulls 3*, 113 pulls 2, 104 pulls 1
Attached Thumbnails What do you use to retard your timing?-hpt-iatvstiming.jpg
Old Aug 26, 2004 | 12:05 PM
Eugenio_SS's Avatar
that's what I have
Old Aug 26, 2004 | 01:52 PM
Dave@Ramchargers's Avatar
Give us a call and we will get you one.. not a problem.
Old Aug 26, 2004 | 04:21 PM
V6 Bird's Avatar
If you're good you can run a dry kit all in the same tune and have it retard when it reaches a certain load on the MAF. Thats how i do it.
Old Aug 26, 2004 | 04:29 PM
DEEZ98Z's Avatar
Thanks for all the imput!!! I will be ordering one in the near future
Old Jun 20, 2007 | 11:56 AM
South's Avatar
Who has done this what is the value of the resistor? where do I Put it?
