Is this a good setup?
So with that said does this look safe..
Timing tuner
WOT Switch
window switch
One of the actual kits.. anything im looking past?
Once you get comfortable wiht the nitrous your going to want to try the 150 shot. Walbro pumps are relativley cheap and simple to install so I would say get one too. BTW: if the kit doesn't come with a filter or atleast filtered fittings get one. You'll find that a bottle heater and a purge is really nice to have and almost nessesary but, you could get those once your already set up. It's just easier to install it all at once if you got the cash to do it.
Again get the window switch, bottle warmer, purge and their entire kit. AND THE FUEL PUMP!!!!! What risk
the engine???? I "believe" RaceX have recently release the 99-2002 ver. Well worth the $$.I personnally, I wouldn't use my money on a A/F swtich or a timing tuner. Get a real tuner - I use LS1Edit - but HP will work. That way you can down load the program you want to run. One for engine only, one for 100, 150, 200, 250. What ever.
I see you engine mods - which are great, but how about suspension? Tires? If you can't put it to the pavement, it ain't ****.
David
https://ls1tech.com/forums/nitrous-oxide/213695-september-nitrous-specials.html
Dave
DynoTune sells a slick one with all the gagets
www.dynotune.org
Cheers
Dan
