NX solonoid mounting location
Old Oct 9, 2004 | 10:57 PM
beachbird13's Avatar
Default NX solonoid mounting location
I am in the middle of a NX wet install and cant decide where to mount solonoids.....my friend wants to mount them on the a/c condenser bracket but it seems really close to the exhaust manifold. Also, it's right above the open part of the engine compartment...wont the rain and elements affect the proper operation of the solonids (ie if they get wet)....we ran the line today and kinds got stumped as to where the solonoid should mount. Seemed like the line came up a little short...we ran it over the rear end and then along the body. This is my first install as well as my friend (his only other N20 install was a Zex kit on a honda) Also, he wants to run the nozzle into the spot on top of my manifold where the egr is on 98-00 cars (LS6 manifold) with one line to the fuel noid and the other going to the n20 noid...that's not a great spot? I think it'll look ghey!!
I need some pics and opnions here...
I see typically the noids mounted upright on either side of the Tbody....how do you mount them there? ..I dunno, Im a newbie to this install i need all the imput i can gather...
Thanks..
Mike
Old Oct 10, 2004 | 10:16 PM
daryl2cb@yahoo.com's Avatar
I put mine on the coil mounting bolts, over cylinder 3 on passengerside and over 2 on the driverside(fuel side) I am not sure about the elements I don't drive mine in the rain.
Old Oct 11, 2004 | 01:25 PM
02 Pewter LS1's Avatar
Here is where I mounted mine on the passenger head.
Old Oct 11, 2004 | 02:43 PM
LUV2XLR8's Avatar
Don't know if you have a STB ( strut tower brace ) but if you do, thats where I mounted mine - worked out OK and doesnt look too bad
Bob
Old Oct 11, 2004 | 09:56 PM
So it is cool to mount off front of head..! Cool because the guy im working with fabbed a bracket to mount all three at a 90 degree right off the head. Kinda riding low between the condenser and the head...
Another question i had was regarding the place to tap for shark nozzle...can it be tapped into the neck of the intake manifold? Will I need to activate at a higher rpm to insure enough vacuum?? Or should I just go buy a new piece of fernco and tap in between the maf and tbody?
Old Oct 12, 2004 | 07:20 AM
69_YENKO's Avatar
same question, i should be getting the same NX kit in about a week.
Old Oct 12, 2004 | 08:06 AM
I would just tap into the back of the maf like I did. Take it apart and at the back of the maf end drill and tap to the thread size of the nozzel and use some lock tite. It will not move and is a better option than using the bellows.
Old Oct 12, 2004 | 01:03 PM
jeremyferguson's Avatar
I like that idea a lot....do you happen to know the thread on the nx shark nozzle??
Old Oct 12, 2004 | 01:17 PM
It is 1\8 " thread
Old Oct 12, 2004 | 02:04 PM
Cool, thanks. I wonder if I can buy just a tap for 1/8" npt or if I have to buy a whole new tap/die kit to get one.
Old Oct 13, 2004 | 08:46 PM
Default Pics finally
I said I would post them, it took for ever to get a digital cam. With no further ado i will post them one at a time. well it looks like they are to big to post. I will find another way.
Old Oct 13, 2004 | 09:07 PM
If anyone knows of free image hosting let me know. Anyone that is curious of the pics just pm me for now and I'll email them to you. I also have templates for the ash tray panel sort of like the jimmy jams, if you are interested the cost is 37 cents(for a stamp). I also have pics of the hidden bottle mounting plate to make your own.
Old Oct 14, 2004 | 07:30 AM
69_YENKO's Avatar
If you register at ls1camaro.com they offer free hosting.
also im interested in the ashtray pannel and hidden bottle mount.
Kudoctamoneys@aol.com
Old Oct 14, 2004 | 08:03 PM
17WITHaBIRD's Avatar
I am also interested in them. matt7117@sbcglobal.net
thanks
Old Oct 16, 2004 | 02:25 PM
on the way.
