408ci motor ?
Old Nov 24, 2004 | 03:14 PM
  #41
pewter 01 SS's Avatar
by the way how does that timing thing work. Over here in cali I never hear people saying things about adjusting their timing.
Old Nov 24, 2004 | 03:15 PM
  #42
VINCE's Avatar
Shorty Director
Originally Posted by pewter 01 SS
so your car can be consider that of a daily driver. Because I still want to have the option to drive it anywhere I want. I dont want my car to just be for the track, I want to have the opportunity to show it off to my friends.
Yes you can consider my car a daily driver. It even gets 24mpg on the highway cruising at 75mph in 6th. It has made several trips to FMS in Louisiana. I have AC/DVD and all.. Hell my girlfriend drives the car with no issues.
Old Nov 24, 2004 | 03:25 PM
  #43
see thats the type of engine i would like. Something that would have to trouble driveing around any time I'd like. you said that fms build your motor right. how much did you say it cost you.
Old Nov 24, 2004 | 09:56 PM
  #44
VINCE's Avatar
Shorty Director
I never said how much it cost, but you can shoot candy@futralmotorsports.com a email and she will quote you a price of a duplicate setup.
Old Nov 25, 2004 | 12:06 PM
  #45
2000 Tran Zam's Avatar
Ya, im having Futral motorsports build my 408 motor too. Im still in the process of deciding whether i go turbo, or NA with the juice in the future.
give them a call, they are very very busy, but from what i hear from Vince it will be worth it in the end.
Old Nov 27, 2004 | 09:28 PM
  #46
Mike K.'s Avatar
Originally Posted by 1fstGM
Hey Mike K. what clutch are you using? Do you have dyno numbers before the 90mm set up and the 1 7/8th headers? One more thing what valve springs are you using and when does your cam hit peak horsepower? Just curious.
Ram 910 but its on its way out , before/after numbers were pretty close to the same as afterwards but you have to remember that I added a 12 bolt and moly driveshaft as well as reduced my timing to 24 degrees (full time nitrous tune here) while at the same time adding the stepped headers and the 90MM setup. My cam peakes at 6400 and my valve springs are comp 978's and I'm even using the forbiddin yella terra rocker arms lol
Old Nov 27, 2004 | 11:24 PM
  #47
eviltwins's Avatar
Mike, what's the lift on that cam, and how much compression are you running? Are you spraying 150 on pump gas?
Old Nov 28, 2004 | 01:50 AM
  #48
do you guys think that its a must to have 1-7/8 headers for this motor. I ask this because I have jet-hot headers which I think are 1-3/4", and I was thinking in using them on the 408.
Old Nov 28, 2004 | 01:52 AM
  #49
Mike K.'s Avatar
lift is .600, compression 11.3 :1
yes the 150 is on pump gas but I do put 116 in my alternate fuel cell which feeds only the nitrous
Old Nov 29, 2004 | 12:00 AM
  #50
Elite_Hot_Rod's Avatar
Probably not but if you want to get all the power the engine can make you gotta let it breathe. I run the Kooks 1 7/8" stepped to 2" and I would have gone with the 2" if I could have.
Old Dec 2, 2004 | 08:30 PM
  #51
GueSS Who's Avatar
True dat
I only have 1 3/4 grots on my 408 LOL but it makes 725 to the wheels so I am not complaining. I could make more with bigger headers IMO.
Old Dec 3, 2004 | 01:03 PM
  #52
Originally Posted by GueSS Who
True dat
725rwhp damn thats bad, whats your set up?
Old Dec 3, 2004 | 09:02 PM
  #53
GueSS Who's Avatar
02 35th anniversary SE
408CI iron block
LS1 heads (ported and polished)
245/250 630/615 on a 112LSA on non XER lobes
LS6 intake (Jantzer TB)
Grot 1 3/4 headers to a 3in bullet hanging off the header
TR8 plugs
LS1edit
NX maf kit and shark nozzle kit (lol)
Speed Inc tank and rails
Eliminator pump (-10 up and -8 back)
42lb injectors
Built power glide with brake
John Gobeal 4000 stall
steel drive shaft with 1350's on both ends
Moser 9in (aluminum spool with 389 gears)
tubular front-end
BMR subframes
Wolfe 10pt cage,lca's,phb,Swaybar,torque arm
Hals front and rear
Bogarts (29.5/10.5/15 MT Drags / MT front runners also)
The car makes 456/580 on motor on our dynojet and then 725/850 on the bottle at 900psi. (right where I like it) I plan on pilling up for spring time with a different cam and head setup. Should make around 850 then
