Nitrous Guys: Why did you go with spray?
#45
1 Post
Originally Posted by Ed Blown Vert
True, true. I got sprayed by my friend when I was stock. I got ![Owned](https://ls1tech.com/forums/images/smilies2/owned.gif)
Had to get it.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Had to get it.
Same here except with my jimmy, got wasted by a ford focus with a 75 shot of cousre my jimmy was near stock, Had him by 3 cars at half track, and he slowly starts comming up to beat me by a fenders length. Pissed me off, been hooked to nitrous ever since
#47
1) Inexpensive.
2) Does not add much weight to the front of the vehicle.
3) The weight it does add is usually in the rear where you want it.
4) 75 horsepower one minute, 200 the next etc...
5) Massive torque down low unmatched by any other power adder even roots.
6) On a hot day FI car is off 3 to 5 tenths an N2O car 1 to 2 tenths.
7) No intercooler heat soak.
8) Stealth (hidden) if need be. (see money racing)
9) Can remove it and reinstall in any internal combustion vehicle you own. (Try that with your F1R or Twin Turbo set up.)
10) Does not transmit damaging harmonics to your crankshaft. (SC)
11) Does not create intense heat under the hood. (hard on plastics, rubber, paint, etc)
12) Wear and tear only when you need the hit.
13) Intimidation factor, (hitting the purge when opponent is lighting the second bulb staging.) Priceless!
Yes, as we all know there are a few drawbacks, but I feel the pro's heavily out weigh the con's.
Is a properly set up turbo system superior, Yes!
Will it make more power and is it easier on parts, Yes!
But, this all comes at a price, a very high price.
In addition to this high price, it must be noted, that these benifits are only realized at the highest levels of horsepower development.
I believe none of us are at the Bob Reiger vs Pat Musi level where it really makes a difference.
Thank you for your time.
I hope I have made some type of contribution.
#48
Originally Posted by ZYA_LTR
F/I bangs your motor when you bang the pedal, and yes, any setup can blow up a motor, but same for same, even properly tuned, the N2O is putting more strain on an engine, ask any engine builder, no matter if the engine is built for ir or not, the bottle is harder on parts. If F/I wasn't more reliable/less stressful, than why would it be offered on factory vehicles? I have never seen a factory installed NX kit.
u didnt know they came factory on all northside cars
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
#49
i love nitrous because, some guy tried to fight me last wed, cuase i sprayed on him and he had no idea what was comming and i embarresed him in front of his friends...
he asked if he could look under the car and i said no. I told him i didnt spray and that id race him again with the same results!
