MSD window switch question
Old Dec 19, 2004 | 07:07 PM
riceyum's Avatar
Default MSD window switch question
i know i am going to sound stupid but i need to know where my tack wire is at, i am wiring illiterate and need some help.
Old Dec 19, 2004 | 07:17 PM
PunkNPonys's Avatar
It is one of the white wires connected to the PCM under the hood. I am not sure which number it is but i am sure someone will post up.
Old Dec 19, 2004 | 07:46 PM
Magic Chicken's Avatar
12 Second Truck Club
it's the number 10 wire, but i don't remember if it's on the blue or red connector
Old Dec 19, 2004 | 08:03 PM
V-10 Killer's Avatar
It's the number 10 wire (white) off the PCM ON 99+ VEHICLES ONLY
'98's different
Old Dec 19, 2004 | 08:38 PM
riceyum's Avatar
mine is a 98 the number ten wire is purple so is it still the number ten and do i splice into the pcm wire or try to find it closer to the tach? or is it a white wire?
Old Dec 19, 2004 | 09:01 PM
Tim 98z's Avatar
You can splice into it close to the pcm. But dont splice into that purple wire on #10. I forget what one it is on a 98 but that's not the one.
Old Dec 19, 2004 | 09:25 PM
I have a window switch set up on my '98 TA, but I'm at work right now. I'll post it in the morning when I get home.
Old Dec 19, 2004 | 09:30 PM
BMN's Avatar
BMN
I think it is #35 for a 98.
Maybe this will help. Gotta love the search.
https://ls1tech.com/forums/showthrea...+window+switch
Old Dec 20, 2004 | 08:46 AM
riceyum's Avatar
ok now I have that figured out. One more question and the install will be complete. It says to hook up to a switched 12v source. What are you guys connecting to? Is the remote wire for the radio good for all of these or do I need to find another source? I am brain storming trying to think of the wires that only get power when the ignition is on and I can't think of any but the remote wire on the radio. Thanks for all the reply's
Old Dec 20, 2004 | 08:51 AM
I just grabbed a volt meter and checked in the fuse box (inside the passenger compartment). I found quite a few switched power sources.
Old Dec 20, 2004 | 11:43 AM
riceyum's Avatar
what about the traction control? another post said it was pink and he ran all of his switches through that. What do you guys think of that one? alos if thats a good one where do I find the pink wire?
