Nx Switch Panel Mounting???
Old Dec 25, 2004 | 07:12 PM
'02SS's Avatar
Default Nx Switch Panel Mounting???
how did you guys mount your switch panel?ashtray?little cubby near cig lighter(thats where i put mine)...and im just confused cuz i installed it and it doesnt snap in.its a little too small.i was thinking i might superglue it in there.anybody else do this?i left my wires long enough so that i could work on it, if needs be.TIA. also how does the arm/heater button work?when i go to arm it lights up...but when i go to heater the arm light turns off and the heater turns on.WTF...how does this work?
Old Dec 26, 2004 | 03:48 PM
Green Thunder's Avatar
Pics??
Old Dec 26, 2004 | 06:37 PM
TigerFan187's Avatar
I mounted my NX switch panel under the steering wheel but I have a truck. The arm/heater button works like this-you basiclly cant have the heater on when the n20 is armed. Up is heater down is n20 arm! Here are some pics of mine but its in a truck!
http://community.webshots.com/album/236615365bkwJDJ
Old Dec 26, 2004 | 08:35 PM
V-10 Killer's Avatar
I bought a second TCS panel filler plate, cut and glued the two together , and hollowed out the inside of it. I still had to glue it to the console though
Looks like this:
Old Dec 27, 2004 | 09:26 AM
riceyum's Avatar
on the sides of the switches you have the little staircase locking thing a majig i lifted it up and put a piece of 16 gauge wire in there raising the stair case on (one side of the switches only) and it snapped into place nice and tight, and the last piece of the stair thing is not all the way in though you cant tell, so if you want to take it out you can just use a flat head and pry it back.
Old Dec 27, 2004 | 11:30 AM
slow's Avatar
ditto, the 16 gauge wire trick works great for the 3 wide panels.
You can also use some 1/8-1/4" foam weatherstripping wrapped around the panel, or about 14 wraps of electrical tape.
Ryan
Old Dec 27, 2004 | 07:31 PM
'02SS's Avatar
Looks like this:
i glued it too! but it actually came out pretty good.there was just a little spot i messed up on...my first try.pretty clean, i think.
Old Dec 27, 2004 | 07:33 PM
'02SS's Avatar
i should've just let the board speak,rather than do a jerry-rig really quick.
