Help w/ nitrous setup for street car please...
Should I go with a 150 shot wet kit? Or will I be blowing my tires off when the kit hits?
I've been reading about some 2-stage dry/wet setups and had the idea to run (this is mainly where I need the help) something like a 50 hole-shot and a 2nd 100 shot once into second.....Also, why is the first shot usually dry? I'm sorry if I'm asking a lot, but any help would be appreciated.
Going with Dry you will need to upgrade injectors. 99-00 had 26# and 98, 01-+ use 28#, both are going to be tapped running full bolt-on and anything over 50shot dry, so to me it would be cheaper to go wet all the way on this particular application. With an M6 your going to want a window switch as well. I think if your clutch is good, your going to blow yoru DRs either way. If you clutch isnt up to par, it will slip and need replacing soon. And once your clutch is good then you need to worry about the rear end, slip the clutch out, spin the DR and make sure you dont dead hook, or the 10bolt POS will pop.
So in your case, clutch, DRs, wet kit OR Dry/Wet with Injectors, think about the fuel pump and the rearend later also. TR6 plugs, tune, refill (lots of bottles) and enjoy.
Charlie
I'd like to stick to DRs to avoid buying a 12bolt or 9" so soon AND because pulling up to a race/cruise night with any type of slick (from ET streets to drags) will scare the pants off most other drivers and they'll refuse any action from the car.
An additional switch to control the wet shot is needed. The dry shot would kickin as the pedal is floored, then the time delay switch delays a 1/2 sesond of so, then the second stage kicks in. This helps control traction. Also when you shift you will not blow the tires off as the delay will work on the shift as well. Simply leave the wet stage off if you want and you can run the 50 shot dry any time you want as well
Dan
I wouldnt say safety would be sacrificed by using the wet/dry. Just need the supporting equipment for each. You can use a "Y" fitting on the nitrous line, 1 for the dry and one going to the wet, and then a fuel noid off the rail. But, you will need Injectors and tuning for them; Dry uses the temp vs airflow thru the MAF for the PCM to add fuel, which will already be getting close to tapped out with anything over 50shot and full bolt-on, I believe, I could be wrong.
A single 150 hit doesn't spin badly if you're on a nice tire. Especially since you said you're going full suspension.
Buy a NX wet kit + genx 2 and don't look back.
