Soleniod rebuild & custom bracket Q?
Two questions:
1) Where can one get soleniod rebuild kits or who offers the service? Price?
2) Anyone make some nice custom aluminum soleniod mounting brackets or do I got to fab some up for myself??
Originally Posted by AgentOrange
Two questions:
I need something like this myself, I am wanting to relocate my solenoids to a differenent and more neat location,
Anybody got anything like this out there?
Havent seen to many brackets, I made one myself out of some scrap sheetmetal, originally wanted to mount them under the intake tubing on the backside of the radiator.
Mike, where are you wanting to locate them? When I get back from Afghan I am wanting to start making some brackets to mount both F&N noids on, need to find as many locations possible and try to make one bracket to fit as many needs as possible.
Solenoid reuild parts, what brand? Nitrous Daves I am sure can supply you with all the parts needed, and if its NX, then you can send them in to them for rebuilding, although its relatively easy to do yourself.
What about making a bracket that uses one of the empty bolt holes on the passenger side head?
Maybe even hook them up directly to the dist blocks on my direct port somehow. I just want to make it look neat, I could try some sheet metal and hope for the best,
Mounting solenoid brackets to the head is bad. It will transfer the heat to the solsnoids. If you isolate it might work a bit better, any time your around the head its gonna be hot.
I would try and stay way from there
Dan
Dan
Closed ex-Sponsor Account
Two questions:
On the custom aluminum bracket, you are going to have to make your own. Then it will fit perfect for where you want to mount the noids.
Ricky
Originally Posted by JoeyGC5
02 Pewter, where did you get that fuel rail fitting?
This came with my NX kit. You can buy it from Nitro Daves also.
