What cam for big shot?
Old Feb 9, 2005 | 07:53 AM
Z284U2TRY's Avatar
Default What cam for big shot?
I am setting up a 347 for a large hit of n20 250-350 area. I was just wondering what kind of cam is best for larger shots like this. Should it be split duration? Equal lift? Does a 112 have any benefit over a 114. I was going to run a comp cam 224 but am starting to think this is to small. I want the cam to make good n/a power but shine some on the spray. What about cam timing advanced into the cam strait up 2 or 4 degrees? Any info would be aprreciated.
Old Feb 9, 2005 | 09:30 AM
white2001s10's Avatar
What works best for E.T. is going to depend on your entire combination set up for the big nitrous hit.
As for a cam, I'd go with a custom grind with a wide lobe sep and heavy on the exhaust duration like this:
INT -2, 44
EXH 56, 6
and of course as much lift as your cam grinder can reasonably give you for those duration numbers.
Old Feb 9, 2005 | 01:18 PM
1BADAIR's Avatar
Most nitrous cams have a higher LSA . APE recommended a 114 for me
Old Feb 18, 2005 | 11:30 PM
GrannySShifting's Avatar
you recommending a 222/242 114 LSA on a 113 ICL? now THATS A SPLIT!
Old Feb 18, 2005 | 11:51 PM
Yep Yep
Old Feb 19, 2005 | 01:37 PM
hellbents10's Avatar
LS1Tech Sponsor
That should work though.
Old Feb 20, 2005 | 12:24 AM
Magic Chicken's Avatar
12 Second Truck Club
I'll be running 200-300 shot on a 244/248 w/600 lift on a 114.
Old Feb 20, 2005 | 12:28 AM
itll be a turd on the motor. better be a lot of compression or itll defintely chew into the power stroke NA
Old Feb 20, 2005 | 01:12 AM
Orange Crush 408's Avatar
what about my cam?
