Power loss N/A with TR6?
Old Feb 13, 2005 | 05:22 AM
LS1FIRE's Avatar
Default Power loss N/A with TR6?
Is there a power loss while driving N/A with Tr6 plugs?
Old Feb 13, 2005 | 06:30 AM
30thz's Avatar
not that you will notice driving.
Old Feb 13, 2005 | 07:20 AM
tektrans's Avatar
I lost 6 tenths with the Tr6's NA. Car was just breaking up the whole way down the track. Trouble is they foul up quick with just normal driving. They were ok for just cruising around.
Old Feb 13, 2005 | 07:40 AM
juiSSed1172's Avatar
Sounds about right to me.
Old Feb 13, 2005 | 08:09 AM
jamnut's Avatar
6 tenth's seems kind of high to me. My car has gone 12.45 @ 114.88 NA fully stock internals on a 1.87 60', with TR6's. That would mean that my full weight + 12 bolt + a full 15# bottle of nitrous could have gone 11.8x NA full weight & stock internals on something like a TR55. Now my car isn't a stock internal car anymore, so I can't do a comparison. 6 Tenth's seems kind of high. I would think that 1 to 2 tenth's would be much more realistic. Maybe you had something else going on, or your plugs were really fouled.
My car has always run pretty good on the TR6's.
Old Feb 13, 2005 | 09:49 PM
SuperC1's Avatar
I couldn't tell the diffrence. I use them in a daily driver with no problems...
Old Feb 13, 2005 | 10:01 PM
sickss228's Avatar
I've had mine in my daily driver for about 4 months with no problems either
Old Feb 13, 2005 | 10:07 PM
BMN's Avatar
BMN
Rougher idle, never checked NA time drop though.
Old Feb 13, 2005 | 11:21 PM
1ScrudeDude's Avatar
This is the main reason why I am hesitant with nitrous. Isn't there a way to run strong both NA and juiced?
I don't want to be a "strong nitrous only" car.
Old Feb 14, 2005 | 06:07 AM
tektrans's Avatar
It depends on what you really want the car to do. I have a direct port system on the motor, the motor was built for nitrous. The car went 11.05 on motor alone with 28" tall tires, 3:42 gears, nitrous cam-converter etc.-3500lbs + 116 fuel. I also have very little timing in the car because of the nitrous tuning. If I wanted to optimize for NA runs I could run a 26" tire or steeper gears and re tune for NA, maybe go to a lower octane fuel.
If I wanted to really get crazy with it I could change the cam, converter etc.
Not gonna happen.
In your case if you basically have a strong NA motor with maybe a 100-150 shot and all you have to do is change the plugs when you wanna spray- that's not such a bad deal. Look at it that way.
Old Feb 14, 2005 | 08:48 AM
Yeah, not so bad that way I guess. I would work on how fast I could change them out
Old Feb 14, 2005 | 02:26 PM
mike c.'s Avatar
i lost nothing at all from stock plugs to tr55's then to tr6's. car ran in the same area of times with all three plugs.
Old Feb 14, 2005 | 04:23 PM
396D1SS's Avatar
my tr6 plugs would foul so quick!!! whats a good plug thats good for nitrous and na? will stock ac delcos work?
Old Feb 18, 2005 | 07:11 PM
JEB99TA's Avatar
I've went from TR55's to Tr6's, back to TR55's, back to TR6's. I'm going back to TR55's because at high rpm's mine raz's (fuel lightoff) when I decelerate ... smoke's like a bitch above 5500 rpms.
With TR55's, it doesn't shoot fire out the Borla tips on deceleration and it doesn't smoke at high rpm's.
Old Mar 23, 2005 | 02:38 PM
BriancWS6's Avatar
I ran TR55s in my old car for 8 months. I hooked up the NOS dry kit and installed the TR6s. I could never tell a difference. Car still idled good, revved clean, and they never gave me problems during the 3 months they were in the car before I traded it off. I didn't use the spray much either, just one bottle that entire time. Most driving was cruising town and shorter trips.
About the .6 loss on someones car, I call BS. I had my car on the dyno with both plugs. The peak hp #'s were within 5. This is on different days and we all know it varies a small amount from day to day and the postion of the car on the rollers. I believe there was something else wrong with that car besides having TR6s. Different cars respond differently and I know that, but .6 is ridiculas. Not flaming anyone, just my .02, good luck to you all.
Old Mar 23, 2005 | 05:23 PM
Black02SS's Avatar
I have ran TR6's now for almost 3.5 years. I have tried both and never saw a difference between the 6's and 55's.
Old Mar 23, 2005 | 09:07 PM
mike c.'s Avatar
i've ran the same tr6 plugs for two years on a head,camed and nos car with no problems. my car lost no ET at the track when i switched from stock to tr55 then to tr6's for the nos.
Old Mar 23, 2005 | 09:22 PM
Snapps's Avatar
I have ran my 4th set of TR 6's and never had a loss off the bottle with the plugs. Maybe you fouled one out. Maybe the car will burn it back off . Just a idea
Old Mar 24, 2005 | 07:19 AM
TN94Z's Avatar
I had TR6's in my 94 Lt1 heads and cam car and could tell no difference. I wouldn't worry about the .6 drop..there had to have been something else wrong in that situation, that is a very big drop.
Old Mar 24, 2005 | 09:38 AM
Mike K.'s Avatar
I have not noticed a difference between stockers and tr6's either. I have not dyno'd with both plugs though so I cannot tell you 100%
