getting there
Old Feb 18, 2005 | 09:51 PM
383LQ4SS's Avatar
Default getting there
should be able to fire her up tommorrow.
Old Feb 18, 2005 | 10:02 PM
SLowETz's Avatar
Wooffff.....
Old Feb 18, 2005 | 10:13 PM
CAT3's Avatar
Restricted User
Wow! The !Cowl makes a humangus difference. Holy **** Al, you da Man!
Old Feb 19, 2005 | 06:34 PM
383LQ4SS's Avatar
Old Feb 19, 2005 | 07:57 PM
gator's 99TA's Avatar
Al, that is some hawtness. gonna have to come over to hear her! can i reserve my spot for shotgun once you get it together?????
Old Feb 20, 2005 | 12:03 AM
Quick 99's Avatar
Really looks interesting with the cowl, nice clean setup with the ss tubing, good job
Old Feb 20, 2005 | 01:15 AM
Orange Crush 408's Avatar
awesome!!
Old Feb 20, 2005 | 06:45 AM
smokeum99ta's Avatar
Yup you got me jelious.Looks awesome!!! I hope mine looks as good as a that when Im done.
Old Feb 20, 2005 | 11:10 AM
SDB's Avatar
SDB
how much for the EGT data loging set up for use with the koks headers....I don't need it now, I am only runing a 200 shot, but later on when I go diret port it could save an expensive motor!
You gonna run 9.20's at 149mph....my guess...
Old Feb 20, 2005 | 11:22 AM
thebernsZ28's Avatar
That looks nasty
Old Feb 20, 2005 | 12:22 PM
383LQ4SS's Avatar
I think these Kook 1 7/8 stepped to 2" with these collectors and the EGT bungs welded in where around $1100. The Red Alert Alltronics 8 EGT datalogger is $999 new. I got a good deal on both by shopping around.
Id be happy with 9.20s at 149
Old Feb 20, 2005 | 01:25 PM
sleeperstyle's Avatar
be sure to post up some videos- everything looks VERY professional on that monster.
Old Feb 20, 2005 | 07:34 PM
Mike K.'s Avatar
nice man, have you started it up yet? and did see a power steering pump on there?
Old Feb 20, 2005 | 09:09 PM
383LQ4SS's Avatar
Of course it has power steering...its a STREET CAR!!!!
Old Feb 20, 2005 | 09:16 PM
396D1SS's Avatar
looks awsome, I seen your car run with the old setup and it was pretty quick.
What kinda times are you shooting for?
Old Feb 21, 2005 | 06:35 AM
BTL FED's Avatar
Do you know what kinda of limit you are looking for on the EGT's?
Old Feb 21, 2005 | 10:23 AM
Turo's Avatar
damn that looks badass!
Old Feb 21, 2005 | 10:55 AM
383LQ4SS's Avatar
I have no idea what to look for on EGTs. All of the research I have done on the subject has told me there is no set temp point to look for and that all cars will be different depending on location of the probes, and many other variables. SO what the idea behind the 8 EGTs AND the onboard wideband is.......
Begin tuning the car on the dyno with smaller shots keeping an eye first on the wideband to ensure it is the right AF ratio..double check with plug reading. Then ensure that...while the AF ratio is good...all 8 cylinders are matching in thier temps. If one is off bring it in line with the others. Then begin to raise the size shot keeping an eye on the wideband AND the egts. I should be able to gather enough info during this process that I will come up with my own max EGT and will know when something is abnormal on any cylinder.
Old Feb 21, 2005 | 12:22 PM
BTL FED's Avatar
That sounds good, I know on my Turbo diesel the max EGT is around 1450-1500, because thats when the aluminum in the turbo starts melting
Old Feb 21, 2005 | 11:27 PM
Futral's Avatar
Default ah **** yall....
hmm..Looks like we will have a heated battle for the 8's
Still looking good Al hurry up and get it running. Did the new rockers work out?
BTL FED...HUH,what the hell are you using that gun for?
