What ever happened to the NX 85mm LS1 intake?
Old Mar 20, 2005 | 12:57 AM
V-10 Killer's Avatar
Default What ever happened to the NX 85mm LS1 intake?
The estimated arrival date for this was Feb 2004.
Any new news?
Old Mar 20, 2005 | 06:03 PM
Anonymous's Avatar
10 second playa
I never heard of this?
Old Mar 20, 2005 | 09:07 PM
Nitro Dave's Nitrous Outlet's Avatar
The intake is in final stages.It has taken longer than planed.It will be out soon.
Dave
Old Mar 21, 2005 | 03:59 AM
Mike K.'s Avatar
hmmm any pics of this at all?
Old Mar 21, 2005 | 08:09 AM
Old Mar 21, 2005 | 04:38 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
Ok intake has been a nightmare to say the least. It is final pouring stages now. Throttle body had to be redrawn with a new feature that any nitrous user will like. The vortecs did have to be remove thou, so I should have more of those in roughly 4-6 weeks. The intake will be coming with rails, the stock units just would not work.
Ricky
Old Mar 21, 2005 | 08:47 PM
69firebird's Avatar
could you give us a idea as far as price? And when do you think it would be ready? Between you and BBK we cant get another ls1 intake to marker
lol
ed
firebird455@gmail.com
if you dont want to post could you PM please thanks
Old Mar 22, 2005 | 11:57 AM
NXRICKY's Avatar
Intake will go for just under 1K. That will include a set of high flow fuel rails, brackets, and installation hardware for you oem connections.
Ricky
Old Mar 22, 2005 | 12:11 PM
Turo's Avatar
Stock TB will work?
Old Mar 22, 2005 | 01:07 PM
NXRICKY's Avatar
With a 3/8" spacer no problem.
Ricky
Old Mar 22, 2005 | 02:34 PM
Anonymous's Avatar
10 second playa
This looks like aluminum in the picture?
Is it? Or is it a silver composite like the LSX?
Why is it 85MM? aren't 80mm and 90mm the standard?
What are the inherent advantages supposed to be for this unit?
In other words, Why should I purchase this unit instead an LSX intake or just keep my ZO6 intake? (PS. I am a NX customer just asking valid questions)
Old Mar 22, 2005 | 03:06 PM
NXRICKY's Avatar
85mm why not, It fits good with our throttle body, the intake is aluminum. Also there are NXL injectors allready built into the intake, So if you want to have a direct port is pretty much is already there. A few lines, some jets, couple of noids and your done.
Ricky
Old Mar 26, 2005 | 02:56 PM
69firebird's Avatar
this intake is going to be nice, really as long as it flows about the same as the LSX, this is going to be a better peice, already has the DP ports in it, instead of bosses for it.
I just wonder between this intake and the BBK, if it is ever released if FAST is going to reduce the price of theirs.
and the FAST throttle bodies are way to expensive. your looking 1600 for this intake with TB and the required parts for a DP setup. Its going to make alot more power with that then the same priced LSX will.
Old Mar 28, 2005 | 09:28 AM
NXRICKY's Avatar
Ok not sure about the differences in intake yet. Testing we had done showed a increase in hp and torque across the board start to finish. Now just waiting on the production unit, and to put our car back togther and back to the dyno. One thing on the throttle bodies, you make the hole to large you loose all streetablitiy. What I mean is the off idle is extremely touchy, and the 85mm seemed to be a real good stopping point.
Ricky
Old Mar 28, 2005 | 11:50 AM
Wicked_Hugger99's Avatar
what kinda power increase are you lookin at w/ the 85mm intake and 85mm TB over the LS6 intake and ported stock tb? Is it for DP setups only or will it work well w/ the nx single nozzle as well?
Old Mar 28, 2005 | 11:55 AM
JL ws-6's Avatar
Race your car!
I assume that thre will be a package available with the TB included. If so, what are we looking at price wise compared to the fast?
I was planning on a fast 90/90 setup to me one of my next routes, but this loks to be a better way to go, as a DP setup is 1/2 there already... and I know that I'll be going that route eventually.
Keep us posted as to the results. I'd like to see a dyno comparison of this setup with your 85mm TB compared to a ls6 with a ported TB, and a 90/90 fast setup... that should give everyone a real good idea as to how it ranks.
Old Mar 28, 2005 | 02:06 PM
NXRICKY's Avatar
Ok our testing show 10hp and torque start to finish Across the board. The direct port that is build in is the NXL injector Bungs. The intake when it leave the our factory will be plugged. There will be a completer kit that will supply all neccessary parts to turn into a direct port. Pull the plugs, install the fittings where the plugs were, install the jets and plumbing and you are done.
Ricky
Old Mar 28, 2005 | 11:22 PM
Mike K.'s Avatar
Pretty cool stuff, where those 10 hp gains over an lsx? was the lsx port matched?
Old Mar 28, 2005 | 11:39 PM
Somebody09's Avatar
Originally Posted by V-10 Killer
This unit looks as though it's for 1998-2000. I have a 2002 and honestly don't want to deal with that hole on the top of the intake. Will there be a second design to accomodate the 2001-2002 EGR(??) setup!? Removing the emissions system isn't exactly an option for me...
-somebody
Old Mar 29, 2005 | 01:41 AM
red90cobra's Avatar
all this talk bout porting makes me want to port my intake
