Here's What I Got.
Old Mar 22, 2005 | 09:29 PM
BlownChevySS's Avatar
Default Here's What I Got.
10lb NOS bottle
NX Fuel Solenoid
NX Nitrous Solenoid
Line
Gauge
What I am guessing is the WOT switch
Jets
Basically what I am asking is what other misc. fittings might I need? I know I still have to get the warmer and pressure switch. I want an automatic warmer too, or at least something that doesn't let me activate the nitrous if I step on it outta the hole at the track. All help is appreciated.
Old Mar 22, 2005 | 09:39 PM
Z284U2TRY's Avatar
relay and wiring will be needed also good thing to use is a window switch. Depending on local track they may want to see a blow down tube. your bottle have a gauge?
Old Mar 22, 2005 | 09:40 PM
What is a window switch?
Old Mar 22, 2005 | 09:44 PM
Z284U2TRY's Avatar
the search is your friend. It cuts the n20 on and off at the rpm's you set.
Old Mar 22, 2005 | 09:59 PM
Is it like the switch for cable actuated TB's or not? and the bottle has a gauge.
Old Mar 23, 2005 | 07:19 AM
Z284U2TRY's Avatar
no that switch i what you already have so the n20 activates whent he pedal goes wide open throttle. Search window switch and you will get a better idea of what it is.
Old Mar 23, 2005 | 09:14 AM
Nitro Dave's Nitrous Outlet's Avatar
Yes you will need the following.
Toggle switch
Wiring harness and Relay,
Nitrous pressure gauge
Heater
Window switch
NGK TR6 plugs
Wiring and connectors ofcourse.
The window switch is the best safety device on the market.It is used to keep you from spraying under to low of a rpm.Its is also used to turn the nitrous off incase you miss a gear or the tranny slips.This will turn it off before hitting rev limiter.
Dave
Old Mar 23, 2005 | 04:19 PM
I have the gauge and the plugs. I am not sure if I need a blow down tube, but what exactly does it do?
