the biggest shot
Old May 24, 2005 | 07:44 PM
ls1marine's Avatar
Default the biggest shot
what is the biggest shot u can run on a stock bottem end
Old May 24, 2005 | 07:50 PM
Race Car Driver's Avatar
11 & 7 Second Clubs
Old May 24, 2005 | 08:30 PM
NOSjohn's Avatar
Restricted User
With a progressive controller I hope...or no? I know BMR was hitting that '04 GTO with 200...but wondered if it was a direct port or progressively controlled.
Old May 24, 2005 | 10:12 PM
Navy David SS's Avatar
I ran a 200 shot last year - TNT wet system. Best times in my signature. Possibly going to a 250 shot this year. No progressive controller. Right out of the hole off the trans brake.
The key: great suspension; an aftermarket fuel pump; bigger injectors; a great tune.
David
Old May 24, 2005 | 10:24 PM
MakoLS1's Avatar
I dont know, with a good fuel system and an experienced and real good tuner tuneing your car id say a 250 shot. But the rod bolts might not hold up to that kind of power. 250 is alot of gas. Safely id say a 200 shot all day long.
I can say with experience a 200 dry shot on stock tune and fuel system is to much.
Old May 24, 2005 | 10:31 PM
beardWS6's Avatar
I`ve got H/C and 150 shot. Just hold on!!!
Old May 24, 2005 | 10:35 PM
gator's 99TA's Avatar
guys here in tampa have been running dual stage 300 shots for years on stock bottom ends. dont know whats takin the rest of the country to figure it out
383LQ4 - the moderator was one of the first to do it on these motors. hundreds of "passes"
Old May 25, 2005 | 10:34 AM
NXJeremy's Avatar
Safely without any issues I would say 200hp. A friend of mine has been doing it for a couple of years now. Using multiple stages or prog. controllers you could probably do quite a bit more (250-300?).
