Direct Port!
Old May 29, 2005 | 07:32 PM
150shotWS6's Avatar
Default Direct Port!
I dont know anything about Direct Port Nitrous! I see a lot of LS1's running it! Why do so many people run DP kits and can they cause backfire in the manifold at a higher risk than wet kits?
Old May 29, 2005 | 10:42 PM
paspar2's Avatar
I probably shouldn't be replying to this but.... A direct port is a wet kit... and (correct me if I'm wrong) but it really takes down the chance of a backfire because it limits gas puddling in the manifold because it fires into the port, not the manifold. You get an optimized distribution of fuel and No2 between chambers.
Old May 29, 2005 | 10:45 PM
JRick212's Avatar
With a direct port kit the nitrous/fuel is being shot directly into the combustion chamber. The intake plenum is not being filled up with gas so if there was a back fire there would not be all that volume of gas and nitrous to explode.
A Direct port kit is also going to be more balanced across the board. Each cylinder getting the same hit.
edit: yeah what he said....didn't mean to copy you didn't see your post
Old May 29, 2005 | 11:41 PM
150shotWS6's Avatar
Using NX piranha kit! would I still need to upgrade my stock internals running a 125 shot?
Old May 30, 2005 | 08:22 AM
BMN's Avatar
BMN
Nope.
Old May 30, 2005 | 10:58 AM
BTL FED's Avatar
If you are only running a 125 shot I would stick to a standard single nozzle, they work great, they are cheap, and alot easier to deal with for a nitrous beginner, if you are thinking of going over 200 then start thinking about a direct port.
Direct Port Pro's:
1. Able to make as much power as you want
2. Able to tune each cylinder
3. Not flowing Fuel through the intake
4. Look Mean as Hell
Direct Ports Cons:
1. COST
2. To Change A/F you have to change at least 8 Jets
3. To Change Horsepower Ratings you have to change at least 16 Jets
4. Plumbing the Intake
Not Saying I dont like Direct ports, hell my motor has 2 direct ports on it
Old May 30, 2005 | 12:10 PM
Robert56's Avatar
Direct Port Pro's:
Direct Ports Cons:
1. COST
I agree, and when can you come plumb my motor? Nice set-up.
Old May 30, 2005 | 04:38 PM
Randy WS6's Avatar
Here's my pro fogger N.O.S. 250 shot.
Old May 30, 2005 | 07:53 PM
mr2guru's Avatar
Hello and welcome to about $600 in AN fittings alone
Old May 31, 2005 | 03:56 AM
ITLstallion04's Avatar
Heres a few pics of my N.O.S. Direct Port on my 383. 150-250 shot.
