What happened to the thread on the New NX Controller
Old Jul 11, 2005 | 11:20 AM
Airwolf's Avatar
Default What happened to the thread on the New NX Controller
Title says it all. I was looking for more info on the new 2 dial NX controller and can't find it anywhere. Was it pulled? Is this unit still available from NX? I thought the thread listed the price from Nitro Dave at $287 or so... Dave, Is this correct? Any info will be great!
Old Jul 11, 2005 | 01:10 PM
Nitro Dave's Nitrous Outlet's Avatar
Mike,
After further testing.NX has determained that these systems are best off left to the motorcycle guys.The larger solenoids are to much for this unit.I deleted the thread so no one would be mislead.
Dave
Old Jul 11, 2005 | 04:16 PM
CAT3's Avatar
Restricted User
That was the one I was referring to as well Dave! Damn it. Back to the drawing board.
Old Jul 11, 2005 | 05:43 PM
Airwolf's Avatar
Well, THAT SUCKS!
Ok, I'm calm now. What would you recommend that does a similar job? The 20 second program feature it had was exactly what a manual shift needed. What else can do this, meaning run a 20 seond program regardless of the activation switch going on and off as I lift off the gas for a shift?
One last thing. When I was reading the specs on that controller it stated 45 amps for "EACH solenoid output". Do the larger solenoids pull more then that? I know I am only using a 40/50 amp relay for both!
Old Jul 11, 2005 | 08:09 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
Hang tight guys, we are working on another progressive unit. NO computer needed, will allow start,ramp, and final. Possible tps switch included.
Ricky
Old Jul 11, 2005 | 08:34 PM
1QUIKWS6's Avatar
Active Streak: 30 Days
Include window switch capabilities, and more importantly - timing retard for LS1 and you've got a definite winner!
I'm looking for a 'one box does it all' installation - instead of having to hook up multiple units and try to get them to work in sync.
Old Jul 11, 2005 | 08:49 PM
NXRICKY's Avatar
Maximizer, and working on the retard stuff.
Ricky
Old Jul 11, 2005 | 08:51 PM
1QUIKWS6's Avatar
All righty then! Any idea on a rough price - got to know how much to save for the controller beside all the other accessories I have to get.
-Jay-
Old Jul 11, 2005 | 09:49 PM
UGotBeaT's Avatar
thought the maximizer needed a comp?
Old Jul 11, 2005 | 11:35 PM
CAT3's Avatar
Restricted User
Window Switch, whats that . Hell the only two reasons I want the pro-con is to be able to keep a flatter torque curve, but build mad hp, and more importantly is to be a hair safer blasting 200 on stock bottom. I know the bottom can hold it when dialed in, but I love coming out the hole rather hard (sounds like a cheap porno reading) and 200 shot wont make for a good ride off the line with stock rear, bottom and other things.
Old Jul 12, 2005 | 12:11 AM
Eugenio_SS's Avatar
a palm does the job as well.
Old Jul 12, 2005 | 09:19 AM
Airwolf's Avatar
I'm with CAT3. Just need a controller to "soften" the big hit on the low end, BUT need it to work with a manual for me. The NX controller had a 20 second window of operation which would have been perfect for me. Does anyone know of a controller with a similar function?
NXRicky, can NX just beef-up the transistors in the unit to handle the amp draw? I really do not want to go with a unit with all kinds of bells and whistles, just a bullet proof simple progressive with a set window of operation time. I can't believe these would not sell like crazy to manual trans guys!
Old Jul 12, 2005 | 09:41 AM
NXRICKY's Avatar
working on it.
and no to the transistors.
Ricky
Old Jul 12, 2005 | 10:04 AM
NXJeremy's Avatar
The Maximizer II is controlled by PC only for now.
Old Jul 12, 2005 | 10:26 AM
foxspy's Avatar
Originally Posted by NXRICKY
working on it.
Ricky
Do you have an estimate on when it'll be ready? I'll be the test mule.
I still need to come in and get those bottles.
Old Jul 12, 2005 | 10:36 AM
NXJeremy's Avatar
Yea Lee, you do need to come get these bottles....I'm getting antsy to build another car and those black bottles would look good in what ever it is , just messing with ya'. (I'm a sucker for black cars)
Old Jul 12, 2005 | 10:10 PM
UGotBeaT's Avatar
so yall are working on new progressive controller where a pc or pda isnt needed??
bout how long till its done?
Old Jul 12, 2005 | 11:16 PM
foxspy's Avatar
I'll be up there in the morning.
