Wont work!
-Steve-
-Steve-
Does your WS light up when you put direct power to it?
Good luck.
Edit: bypass the window switch and try to spray without it if you haven't already. Make sure the rpm is over 3500 and traction control is off (or competitive mode) before you go WOT.
Edit2: Found the link on Z06vette.com... and who said they were just a bunch of waxers
http://www.z06vette.com/forums/showt...ight=tach+wire
-Steve-
you are most likely running a wire from the fuse to the switch. and then a wire from the hswitch to activate your nitrous kit/selenoid. or fromt he switch to the WOT switcha nd then to your selenoinds. somewhere after the toggle switch the wire may be grounding out, and the only time that you can see that it is grounding out is when the switch energizes the wire.
another possiblilty is that somewhere in your circuit you have the wire going to ground and then when the switch is flipped it pops the fuse.
the last possibility is this. the fuse is too small to run the selenoids and this one i cannot comment on because i have to idea how much current they pull.
