Will I run lean?
Old Jul 22, 2005 | 09:38 PM
MDoe8's Avatar
Default Will I run lean?
heads/cam with 28# injectors ('98 injectors). I have a 100 wet shot that will be going in. Will this max the injectors/fuel pump out? I believe it will be fine since its wet not dry but any input would be great. Thanks for your help
Mike
Old Jul 22, 2005 | 10:50 PM
Matt@HSW's Avatar
How much power do you make now? Since you have a heads/cam set up I would say that you're borderline on the fuel pump. I would upgrade it and play it safe. As far as you injectors it depends how much NA power you are making. As far as the injectors for the wet shot you are correct, they don't come into play.
Matt
Old Jul 23, 2005 | 12:40 AM
red90cobra's Avatar
that fuel pump is probably a little worn out. I'd go ahead and replace it.
Old Jul 23, 2005 | 06:53 AM
GM Muscle's Avatar
I would replace the pump too. They are cheap enough and pretty easy to install.
Old Jul 24, 2005 | 12:52 AM
MDoe8's Avatar
I am making ~425 rwhp right now. Which pump would you recommend? I'm still a noob when it comes to the f body game but I'm learning!
-Mike
Old Jul 24, 2005 | 12:23 PM
Matt@HSW's Avatar
I would recommend the Racetronix kit, but I’m a bit biased as we carry them. But in all honesty they are real easy to install and you don’t have to cut up your factory fuel bucket. The kit comes with everything you'll need. A standard Walbro pump will work too, but it isn’t a plug and play solution like the Racetronix set up.
Matt
-Mike
Old Jul 24, 2005 | 02:38 PM
MDoe8's Avatar
What is all needed for the walbro to work? Matt, any part I can't find used ?I will be going through you guys
-Mike
Old Jul 24, 2005 | 03:39 PM
Matt@HSW's Avatar
You'll need a wiring harness and you'll have to cut up your fuel bucket. There are a few posts that go into the pluses and minuses:
https://ls1tech.com/forums/fueling-injection/342971-there-any-difference-between-racetronix-pump-plain-walbro-255-a.html
Old Jul 24, 2005 | 10:39 PM
MDoe8's Avatar
gotcha, i looked into it and it seems racetronix is the way to go. When I buy the remaining stuff needed, I will be buying that as well fromy ou
-Mike
