relay wiring
Old Jul 26, 2005 | 11:28 PM
FormulaFire's Avatar
Default relay wiring
I have a NX wet kit, and I was wondering if there was any good power source to tap into for my relay in the spare tire well. It will run power to my bottle warmer. OR will I just have to run a line up to the front of the car.
Thanks
Old Jul 27, 2005 | 07:52 AM
hourang's Avatar
run a power wire to your fusebox, connect it to a ignition switched fuse like the radio one. even if there is a power source near by, i would still run the wire to the fuse box so that the heater can only run with the key on.
Old Jul 27, 2005 | 09:07 AM
NXJeremy's Avatar
Old Jul 27, 2005 | 11:12 AM
99ls1guy's Avatar
are there no switched power sources towards the back of the car? when i had my setup i did what you guys said and had it ran to the fusebox, however ive always wondered if there was an easier way to do it.
Old Jul 27, 2005 | 11:29 AM
NXJeremy's Avatar
I run everything than needs a power source to the fuse box, that way if there is any electrical issues you have everything together in the same location.
Old Jul 27, 2005 | 09:33 PM
Somebody09's Avatar
I hate having to hunt for fuses. My friend wired up his Honda and there are fuses everywhere. He also did a shitty job wiring, so trouble shooting his problems is a nightmare!
Old Jul 27, 2005 | 10:24 PM
how do you wire it to the fuse box?got any pics??
Old Jul 28, 2005 | 08:47 AM
hourang's Avatar
dont have any pics of it, but what i do is just strip a good inch off the end of the wire, wrap the wire around one of the leads on the radio fuse, and plug the fuse back in with the wire connected. make sure the wire doesnt contact the other lead on the fuse.
Old Jul 28, 2005 | 08:58 AM
Is this up by the fuse box? Will wiring it to the radio fuse still work if I don't have a radio?
Old Jul 28, 2005 | 09:02 AM
hourang's Avatar
yeah the fuse box on the drivers side dash panel. if the radio fuse is there, it will work.
Old Jul 28, 2005 | 09:18 AM
NXJeremy's Avatar
Wiring into the fuse box doesn't mean that there are going to be fuses in the system. You'll only be wiring to one side (lead) so the current isn't going to be going through the fuses. The only reason for wiring it in that location is so you are connecting to switched power sources instead of constant power, and all your power wires will be in the same general area on the car.
Old Jul 29, 2005 | 02:04 AM
good idea.. now I'll just try and figure out how to get to them..
