What Nitrous for me?
Old Aug 14, 2005 | 04:45 PM
Superman09's Avatar
LS1Tech Sponsor
Default What Nitrous for me?
Hello all. Well next summer my goal is to be i nthe 11's. So all winter i am going to be workin on modding my car while its garaged. I have plans on finishing exhaust with LTs and swapping my borla for True duals. Also adding an LS6 intake and fuddle stall with shift kit and cooler and gauge. Is 3800 25 str too big for nirous or is it ok, would 3600 2.5 be better?
I am also doing a cam swap. Looking at the MS3 with all the junk needed and am upgrading the lifters for added safety. After that some DR's or ET streets and hopefully i can catch some mid-high 11's. Now after this i want to spray.
Safety is prolly my biggest concern as i pay for all this myself and replacing the engine would put my car down for a long time. I am curious if i can still run a 150 shot safely or is that pushing it with the cam on the bottom end or what? Dry, Wet or direct port? Which set up would you suggest and what type of shot. Safety is my biggest concern prolly. Thanks
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Aug 14, 2005 | 04:56 PM
Turo's Avatar
You can run a 150 on the stock bottom end no problem, just make sure your tune is good and your fuel system is upto par (you'll need at least a fuel pump). As far as wet vs dry, it's all a matter of taste nowadays. Personally, I like the wet shots, more torque . Direct port will be a bit overkill IMO if you plan on staying with a 100 or 150 shot.
Old Aug 14, 2005 | 05:07 PM
Superman09's Avatar
LS1Tech Sponsor
Ok so direct port is more for the built guys running 200 and up shots? Whats a good fuel system to upgrade too? Ill start with a 100 shot rpolly and than maybe go to a 150 if i man up enough. My car will be tuned my speed inc, Im having them do my cam and trans and tune and i guess ill have them install the nitrous too. Anyway i can hide this? Is it hard to hide it under the hood?
Ok, now which brand should i go with? Nitrous Xpress and TNT seems popular. Can someone direct me specifically to a nice nitrous kit? I want the whole shebang. All the necessary stuff and all the extras to keep it as safe as possible. Now i should run a window switcxh since im an auto correct? And this means it sprays for me? Like i set it up to spray from 3k-6k and when im at WOT and the nitrous is on, once it hits 3k it will kick in anbd spray til 6 k and shut off threw the shift and start back up at 3 k i nthe next gear for example correct? All info is great. Can someone list all the crap i need in a kit and extras for safety and what not? Thatd be awesome. Thanks
__________________
Old Aug 14, 2005 | 10:09 PM
Matt@HSW's Avatar
Take a look at the Racetronix fuel systems. They are good up to 600 ish rwhp (and up to 650 RWHP with a fuel rail mounted FPR). You are correct about the window switch. I would also pick up a set of colder plugs (NGK TR6s are nice), a fuel pressure safety switch and a bottle heater. Maybe look into a LS1 timing tuner if you want to run more timing NA and pull some when you spray (it also has a window switch built in). Take a look at our nitrous kits; they come with a lifetime warranty. Let us know if we can help you with anything.
Thanks,
Matt
Old Aug 15, 2005 | 05:29 AM
Superman09's Avatar
LS1Tech Sponsor
Alright. Thanks for the info. So what type of kit would you suggest for me? Like a 50-150 wet shot kit. Can someone direct me to a nice NX kit or some brand that comes will pretty much everything i need and is top notch? How about a TNT one, and Matt, which one or your kits fits me best? Thanks
__________________
Old Aug 15, 2005 | 09:43 AM
Nitro Dave's Nitrous Outlet's Avatar
The key to having a safe Nitrous system is the quality of the system.I suggest looking into one of the Nitrous Express Systems.No other company on the market can measure up to there quality.They have many to chose from.Single nozzle system,Dual nozzle system,Maff kit,NXL kit,And direct port.For a 150 shot I would not do a Directport.I would look into either the single nozzle,Maff kit, or dual nozzle kit.WE have some specials going for the month of August that you may like.I suggest upgrading your fuel pump to a intake walboro or a Racetronix system.
You will need a window switch for safety and look into a GENX2 package for a all in one accessory kit.
Let me know if I can help in any way.
Thanks
Dave
Old Aug 15, 2005 | 10:51 AM
Superman09's Avatar
LS1Tech Sponsor
Ok thanks. Well whats the difference between the single, dual nozzel and maff kit?Would you mind to quick explain and tell me which one would best suit me? I am upgrading my fuel pump for my cam, i was going to do the ported ls6 pump? Will this be ok? Also can you lsit all ALL the necessary accesories i need and the ones and i can get if i want to which i will due to i want all the stuff for maximum performance and safety. Thanks a lot Dave for the time
__________________
Old Aug 15, 2005 | 10:56 AM
Matt@HSW's Avatar
Either one of these kits would work for you:
http://www.harrisspeedworks.com/shop...cat=302&page=1
If you think that you're going to go past a 150 shot my suggestion would be for the second kit. We're a bit flexible with pricing; if you're interested shoot me a PM with what you're looking for and I can get you a quote. And since "quality" keeps popping up, just so you know we also have a 100% customer satisfaction policy; if you don't think it's a quality kit we'll give you a refund. That goes along with the lifetime warranty on the product. Let me know if I can help you with any other questions.
Thanks,
Matt
Old Aug 15, 2005 | 11:00 AM
Superman09's Avatar
LS1Tech Sponsor
Ok sounds good,150 will be my max as i dont want to be building my motor. Thanks and ill check those systems out.
__________________
Old Aug 15, 2005 | 11:03 AM
Matt@HSW's Avatar
A ported LS6 pump is usually an oil pump, not a fuel. The 'Vette uses a different style fuel system. IMO your best bet would be for a Racetronix system, or if you're a "DIY" guy you could get a Walbro and a hot wire kit. You'll have to chop up your factory fuel bucket and you will lose some functionally of the stock fuel system if you go the Walbro and hot wire route. Before you make up your mind do a search on here about the pluses and minuses of each. There's a good bit of info.
Matt
Old Aug 15, 2005 | 11:56 AM
Superman09's Avatar
LS1Tech Sponsor
Ok thans. Yea your right, i read it wrong, the ls6 oil pump is what im getting. Id prolly go for the racetronix kit and have it installed as i am not a DIY man and hate chop jobs. Thanks
__________________
Old Aug 15, 2005 | 02:11 PM
The single nozzle is a single nozzle that goes in the bellows between the mass air meter and throttle body.The Dual nozzle has two nozzles that go into the bellows.The maff kit replaces your stock mass air ends with the NX ones.They have a spray discharge built in.Check out our August specials.
https://ls1tech.com/forums/showthrea...68#post3347568
Thanks
Dave
