nitrous
Old Aug 29, 2005 | 10:46 PM
darrell hoagland's Avatar
Default nitrous
what shot can i spray and be safe i have a 96 trans am every bolt on i can put on it
Old Aug 30, 2005 | 11:10 AM
DynotuneN2O's Avatar
LS1TECH Sponsor
A simple dynotune wet kit will work for you. stick to about 100hp if you have lots of bolt ons with a stock engine.
www.dynotunenitrous.com
Let us know if you need more info on that kit.
Cheers
Dan
Old Aug 31, 2005 | 10:17 PM
CrawlinWS6's Avatar
Import Patrol
with ***** to the wall and easy 100-150 shot
Old Aug 31, 2005 | 10:21 PM
tuff's Avatar
8 SEC SLOPPY SHOT!!!
No such thing as safe.Id just pill up to a 200 shot JK just do a 100 shot and you will be fine.
Old Sep 1, 2005 | 09:00 AM
Nitro Dave's Nitrous Outlet's Avatar
Darrel,
I would put a single nozzle kit on the car and pill it for a 100 shot.With upgrading your intank pump you can spray a 150 safely.
Dave
Old Sep 1, 2005 | 07:09 PM
i have the nx kit with mass air hook up done did the fuel pump up grade so 150 shot want be any promblem what plugs do i need thanks
Old Sep 1, 2005 | 10:10 PM
I would run NGK TR6s gaped at 36
Dave
Old Sep 2, 2005 | 07:59 PM
thanks for all the info
Old Sep 3, 2005 | 01:13 PM
Question plugs
are the ngk tr6 plugs high or what
Old Sep 3, 2005 | 01:32 PM
slowpoke96z28's Avatar
i used to use AC Delco R42LTS gapped at .035" on my 1997 LT1.
