Need help piecing together accessoreies for my tnt kit.
ok i bought a tnt F-1 kit and now i need to buy accessories..here is a list of stuff im gonna buy.
1. Tnt purge kit. (where can i purchase this and will i need any special fittings).
2. Bottle warmer..(what brand do you suggest)
3. Pressure gauge. (using a dynotune will i need any special fittings?)
4. Bottle opener..what branfd is a direct fit for the tnt bottle? i dont want to have to modify anything..
and will i need any extra relays or electrical parts for these products? thanks!
Bottle heater.Nx makes a nice sexy one with black element.
The dyno tune pressure gauge is a good choice.You will need a -6 Manafold to put the sendor unit into.
The ZEX remote bottle opener is a direct fit for the TNT bottle.You can also make the NX fit.
Dave
Originally Posted by Nitro Dave's Nitrous Outlet
On the Purge kit.The TNT is a good one.I can put you into a NX cheaper though..
Dave
Dave
When they list the -6 or -4 ythey are refering to the size of the fittings.The one you will need will be determaned by the size of your main feed line.TNT use to use a -4 hose but a -6 fitting on the bottle size and -4 on the solenoid size.I have been told that now there systems are all -6 but Im not sure. However on the heater side since it is the bottle size you will need -6 regardless.
Dave
Dave
Dave
Dave
Not to hijack the thread, but I also was looking at the Zex bottle opener. I can't really find a good picture of it so I can't really see how the housing goes on. Does it work with the 6AN fittings (feed line and blow down tube) and a bottle heater as well?
Do you mean the bottle heater or bottle opener.Here is a pic of the bottle opener.
http://www.nitrousoutlet.com/outlet/...§ion_id=79
Yes it will work on the tNT bottle.
Dave
Dave
LS1TECH Sponsor
If you use a heater kit, the heater kit provides the manifold with two ports so you can simple screw the sending unit for the gauge into that extra hole
www.dynotunenitrous.com
