Should I go with a bigger shot?
I would purchase a Wideband 02 setup if I were you...check your plugs after runs, and run low timing+high octane.
Pour some higher octane fuel in it and you can run timing (I have a different application considering dual poweradder, but I run straight 103 all the time.) Maybe you could start using torco....
Just make sure you pull your plugs directly after a run (by directly after I mean DIRECTLY after, shut the car down through the traps (or street) and coast to a stop (you CAN throw it in neutral). Pull a plug and take notice.
I think with some straight race gas you shouldn't have a problem on a 200 shot, but than again, no promises. (better safe than sorry, have someone back off timing, they say about 1.5* for every 50 shot).
oh yeah, and definately pray!
