how to delay a shot on an M6 till 3rd
u can always mount a micro switch on ur shifter so when u throw it in 3rd it turns on...u'd need one for 4th too.
If that's not an option, a WOT switch or other micro-switch inside the console would probably work. Like Screamin_Z said, you'll need one for 4th gear too.
you can use the reverse of what someone allready said...use the micro switches to turn the nitrous off in 1st and 2nd gears..but you should use it in all your gears...by the time you get to 3rd gear your race will be half over. ;D
Robert
If all you want to do is moly spray it in third on then the cheapest way is to get a WOT switch and then put the activation switch in the ashtray like mine and when you shift to third flip the switch. Thats what I do.
Robert
