Check This out...
Old Sep 30, 2005 | 04:07 PM
Nitro Dave's Nitrous Outlet's Avatar
Default Check This out...
I know this has nothing to do with nitrous.However this is the place where most of the hardcore nitrous guys look so I posted here to.
Ok guys these custom built billit aluminum valve covers. These units use the stock oring gasket, has a oil deflection baffle, clears all valve trains, and a clean double threaded cap. With this style of cap there is less turns to close.Come complete with all stainless steal mounting hardware. Coil bracket mounting stands can be added if mounting the custom coil bracket to the valve covers at no extra charge.Mounting them this way your stock plug wires will still work!!!
The valve covers are 375.00
This is the coil mounting kit.
Its 125.00
Thanks
Dave
Old Sep 30, 2005 | 04:26 PM
BAKED's Avatar
Sexy.
Old Sep 30, 2005 | 04:51 PM
Dustin's Avatar
have any pics of them mounted with the coils?
Old Sep 30, 2005 | 04:59 PM
XTrooper's Avatar
Nice!
Old Sep 30, 2005 | 05:04 PM
Phoenix 5.7's Avatar
no PCV line. those are a nice lookin setup. do the coil brackets mount using the valve cover bolts?
Old Oct 1, 2005 | 11:55 AM
CAT3's Avatar
Restricted User
For PVC just drill, tap and go with AN fittings. Dave, very clean looking. Got pics with the coils mounted? (not sure why I ask since I want to relocate mine).
Old Oct 3, 2005 | 12:24 AM
We can add the fittings for the PCV valve.Just let us know.
Dave
Old Oct 3, 2005 | 12:25 AM
Ill see if I can get some for you.You can also use these brackets to relocate the coils.
Dave
