View Poll Results: where should i put the bottle
on the driveshaft hump between the back seats
37.30%
in the spare tire well
62.70%
Voters: 764. You may not vote on this poll
where to mount bottle
Old Apr 8, 2007 | 08:40 AM
  #261
SHARKZ33's Avatar
did you fabricate the driveshaft hump mounting plate or can you buy one?
Old Apr 9, 2007 | 03:06 PM
  #262
Ramshaft's Avatar
You can buy them from a couple different sponsor here on the site.
Old Apr 9, 2007 | 09:15 PM
  #263
Gold Z's Avatar
Originally Posted by daniel6718
how are you guys mounting them to the area above the gas tank...
Remove the carpeting and weld bolts to the floorboard with the threads sticking up. Put the carpeting back in place. Cut a small X in the carpeting to let the threads stick through. Bolt your mount to the bolts. This is what it looks like when you are finished.....
Old Apr 10, 2007 | 04:54 PM
  #264
daniel6718's Avatar
thats what i was thinking....but no welder...lol
Old Apr 10, 2007 | 11:30 PM
  #265
Gold Z's Avatar
I don't have one either but Ifound a friend who had one. I'll bet you can too.
Old Apr 10, 2007 | 11:50 PM
  #266
Italiankid77's Avatar
Good thing i looked at this,i got some good ideas i think im going to mount it on the hump.
Old Apr 11, 2007 | 09:26 PM
  #267
haighter's Avatar
I like the rear tire area just in case you get pulled over by the cops and people dont know how big of a tank you have if you are going to race.
Attached Thumbnails where to mount bottle-hpim1310.jpg   where to mount bottle-hpim1312.jpg   where to mount bottle-hpim1319.jpg   where to mount bottle-hpim1320.jpg
Old May 10, 2007 | 10:25 PM
  #268
jeffboy757's Avatar
umm what if the cops pop your hood, and see the nitrous soliniods all over the place??
Old May 16, 2007 | 02:48 PM
  #269
South's Avatar
Originally Posted by ty_ty13
i put mine on the back seat bracket on passenger side
fit perfectly
Do you have a picture of this?
Old May 16, 2007 | 02:54 PM
  #270
South's Avatar
Originally Posted by NXRICKY
check this one out from Nitrous Outlet.
I stole the image from another thread, had a lot of interesting stuff on it.
Ricky
Why can’t I mount my bottle is this location without the bracket? What's the advantage?
Thanks,
Jason
Old May 16, 2007 | 05:34 PM
  #271
5_02ls1's Avatar
Default lol
nitrous is not illegal to have ..
Old May 16, 2007 | 05:47 PM
  #272
5_02ls1's Avatar
ok you guys with the bottle laying sideways..you do know its not supposed to be mounted that way?the bottle should be mounted to where the valve is facing the front of the vehicle,so the liquid will move to the bottom of the bottle so it can be syphoned properly..
someone correct me if im wrong
Old May 16, 2007 | 06:01 PM
  #273
Deerhunter-Z28's Avatar
trunk
Old May 16, 2007 | 07:16 PM
  #274
jares99's Avatar
Heres mine just got the bottle mounted still need to polish the plate the bottle sits on.
Got the heater hooked up today but still far from done.
Old May 17, 2007 | 06:46 AM
  #275
KingCobra02's Avatar
I mounted 6 1 pound bottles under the passenger seat....like my man Vin Diesel!!
Old May 17, 2007 | 10:39 AM
  #276
dementia's Avatar
If you have the bottle mounted sideways all you have to do is rotate the bottle 45* so that the siphon tube is towards the back of the car. The bottle angle and the new rotated angle will still lead the nitrous to be at the siphon tube upon acceleration.
Old May 18, 2007 | 12:27 AM
  #277
slowpoke96z28's Avatar
any pics of this?
BTW, finally wired the arming switch today at work. took power from pin 9 on connector C1 on the radio(its fused, and powered in run, accy, and rap) and took ground from the bolt on the console mount right behind the shifter. the wire to the microswitch is run under the carpet to the gas pedal where the microswitch is mounted. i like how the arming switch glows when its on, lol.
Old May 19, 2007 | 01:12 AM
  #278
Robert56's Avatar
It's is an exceptable option. you still want the valve end higher, and just rotate the bottle to 45* so as the pickup tube is towards the back of the car, as per NOS's rec. here's how they said to do a C5, my buddy's Z06.
Robert
Old May 22, 2007 | 07:53 PM
  #279
mikey8108's Avatar
you know the towels around the bottle keep it warm
Old May 22, 2007 | 08:13 PM
  #280
Lythropus's Avatar
That's pretty funny, is that a civic hatch?
