where to mount bottle
very simple to make you could get yourself some quater in thick aluminum or you could do what i did and find a street sign and cut it in half. then all you need is some 1/4 inch rubber and some steel L brackets. after that you just need patience in drilling the correct holes for mounting and for the bottle.
Here's my setup. I used the bottle mount plate from Nitro Dave and just ran my lines through the grommets under the rear seats.
Thats nice.
Will it pass tech? I want mine on the hump but if it wont pass tech then I guess its the tire well
no tech here either with the blow off inside the car. You need the blow off to be routed outside the car. I put mine in the tire well and used a bulkhead. I'll snap a pic and post. Also you dont want your bottle laying flat like that. You want the front end higher to keep the pick up at the bottom of the juice supply. Like on the hump. See how its tilted. Will it pass tech? I want mine on the hump but if it wont pass tech then I guess its the tire well
