where to mount bottle
http://www.corvettekillstories.com/p...s/100_0390.JPG
edit: i just posted the link b/c the pic is huge
How thick is the plywood...i was thinkin of doin the same thing as you did. I was thinkin of using 5/8 plywood and gorilla gluing/liquid nailing the wood down to the metal. Then, bolting down my 15lber. Also, anyone have any ideas on where to run the blowdown tube in that area?
as far as the blowdown tube....goto the hardward store and buy a long piece of rubber tubing and slide it on the end of the blowdown tube. then run that rubber tubing down by the spare tire and there a rubber grommet that you can cut a hole into a put the tube thru that so it will vent into the atmospehere
Will do...I will have to bring in that tube tomorrow to my local parts store and see what size tube can fit over it. Thanks.
Vinny
