Propane information
Old Oct 23, 2005 | 12:15 AM
  #61
Robert56's Avatar
Originally Posted by n2ojunkie
Good to hear your doing ok.
And sence your back I take it your jetting chart is for a single or duel nozzel setup and not a DP set up right? If so anyway to work it out for a dp kit?
It's hurting for certain, and I just double up on the Oxy Codon.
Yea it's for a single nozzle set-up, where you replace the gas with propane. I'll have to think about it for converting known numbers to DP (math).
Robert
Old Oct 23, 2005 | 10:48 AM
  #62
LT99LS1's Avatar
Originally Posted by NitrousDirect
smallest i have is 8lbs i think
Vert or Hoz?Price?
Old Oct 23, 2005 | 11:14 AM
  #63
n2ojunkie's Avatar
ok thanks.
Old Oct 26, 2005 | 02:08 PM
  #64
99blancoSS's Avatar
heres a pic of the bottle with dimensions
http://www.rei.com/product/4398.htm
Old Oct 26, 2005 | 02:24 PM
  #65
fitz98ta's Avatar
thats pretty much the bottle i have.
Old Oct 26, 2005 | 02:28 PM
  #66
99blancoSS's Avatar
and you have it upside down where?
Old Oct 26, 2005 | 03:09 PM
  #67
fitz98ta's Avatar
i have it mounted in the spare tire well. i cut a board that mounts about halfway up in the well and then i cut a hole in it big enough to let just the top part of the bottle stick through it, then i just have straps holding it in
Old Oct 26, 2005 | 08:46 PM
  #68
Robert56's Avatar
That bottle will also fit in the vette spare well, with/without a cover. I don't want tech to see it so I was going with a smaller bottle.
Robert
Old Oct 26, 2005 | 09:20 PM
  #69
LT99LS1's Avatar
Did you guys remove the OPD off the tanks? or does this tank even have one new?
Old Oct 27, 2005 | 10:29 AM
  #70
fitz98ta's Avatar
i had to remove the overflow saftey valve because my bottle is upside down.
i don't believe you have to if you run it right side up.
(correct me if i am wrong robert)
Old Oct 27, 2005 | 11:17 AM
  #71
99blancoSS's Avatar
I'm concerned about keeping propane stored inside the vehicle, it would be nice if someone made a tank that fits in a desirable location externaly. I know you can have made what ever you want, it would be much cheaper to order in quantity though. Robert had the right idea of finding someone to bankroll him... anyone grabbing the bull by the horns here would have ground floor opportunity. a long skinny cylinder with the valve in the side? blow off protection? Something safer than a charged propane cylinder inside the car. You take a rupture on the system and it could get hot quick inside the car. Just a concern I have. Thought about the 1# (if they last as long as the nitorus tank)under the hood but I guess engine heat would be a problem.
Old Oct 27, 2005 | 03:00 PM
  #72
fitz98ta's Avatar
something else to be considered is just using a 2.5 lb nitrous bottle but have some type of adapter made that would allow the filling station to pump propane into the n20 bottle instead (and then of course finding someone that would actually pump propane into it)
that way you have what could be a little more stable container and blow off protection. plus it would look better if you had to have it in the open
Old Oct 27, 2005 | 03:40 PM
  #73
Robert56's Avatar
Just like a n2o bottle, if it gets too hot you have to have an escape for extra psi or bottle will blow up. This is another safety issue running propane in the interior, esp if your a smoker. Now chances of the bottle getting hot enough to blow up is small, but...
Robert
Old Oct 27, 2005 | 03:44 PM
  #74
Robert56's Avatar
Might be good idea. could have a 5/8lb mother bottle at home.
Robert
Old Oct 27, 2005 | 04:01 PM
  #75
fitz98ta's Avatar
Robert
well actually i never thought about going to get like say a 20 lb bottle filled, convert the fitting to AN and then syphone or pump that into a n20 bottle.
VERY good idea robert, but would you have to take the pick up tube out of the n20 bottle since a propane bottle doesn't have one?
i am sure if you walked up to a propane filling station with a nitrous bottle you would be laughed at.
Old Oct 27, 2005 | 05:04 PM
  #76
Robert56's Avatar
You'ed have to play with discs in blow off on n2o bottle as their release pressure is mucho higher than propane would ever see, or maybe because a n2o bottle is rated at such a higher psi wouldn't need anything?
Robert
Old Oct 27, 2005 | 05:38 PM
  #77
99blancoSS's Avatar
Right, why would you need a blow off if the container is a lot stronger than any pressure the gas would ever see, unless its a federal fire saftey code type of thing being where its better to dump the pressure in case of a fire than wait until the bottle blows.
Old Oct 27, 2005 | 08:28 PM
  #78
Robert56's Avatar
IIRC the n2o bottles are rated at 3500psi and burst disc around 1500psi. I do know as fact that heating a propane to 95* results in 160psi, so you would have to have a propane filled n2o bottle in a fire to cause enough pressure for an explosion.
Robert
Old Oct 28, 2005 | 08:32 AM
  #79
fitz98ta's Avatar
it would probably be better if it never blew the valve because propane STINKS
Old Oct 28, 2005 | 10:56 AM
  #80
PAGregSS's Avatar
How do you go about filling a bottle with propane? It doesn't need to be pushed in like nitrous, does it? Do you just simply attach it to a bigger bottle and open the valve and when the pressure equalizes, it's filled? If it's that simple, I think I may go the route of the 2 lb nitrous bottle and fill it myself from a large propane tank.
