New progress pic...
Old Oct 11, 2005 | 10:55 PM
Phil99vette's Avatar
7 Second Club
Default New progress pic...
I am still not 100% happy with the lines but we're getting there. What do you guys think, I need some help getting this finished.
Old Oct 11, 2005 | 11:14 PM
Brandon Boomhauer's Avatar
looks pretty good
why arent you pleased?
Old Oct 11, 2005 | 11:16 PM
Nitro Dave's Nitrous Outlet's Avatar
Its looking good.Im guessing you are going to polish the rails? Its hard work huh.Now you see why we charge 350 for doing that.Many man hours. You are doing a great job Keep it up.
Dave
Old Oct 11, 2005 | 11:23 PM
7 Second Club
I am just a perfectionist. I am not 100% happy because there are differences within the lines and I have yet to figure out exactly how to bend the lines and get repeatable results. We're either going to polish the rails or powdercoat them mirror black. Your not lying about hard work!
Tomorrow we're going to drill the driver side, start fabrication on the aluminum brackets for the rails and solenoids.
Phil
Old Oct 11, 2005 | 11:25 PM
Well Phillip.Im the same way.However this is your first time and you deserve to pat your self on the back.I have seen alot of first timmers and this is nice.
Dave
Old Oct 11, 2005 | 11:27 PM
7 Second Club
Thanks coming from a nitrous guru, it really means alot! You may be hearing from me soon....
Phil
Old Oct 11, 2005 | 11:41 PM
Robert56's Avatar
Phil
I am very **** about this stuff also. At work sometimes I'll have a piece that has 10/15 bends, going around somthing, up a wall across a bulk head... I have rebent pieces many times. What I do to be consistant is use witness marks. Like Dave said it is good for a first timer. It can take a long time to get it down where you are quick and correct. It allways feels good to do your own work, though, so the pay off will be well earned.
Robert
Old Oct 12, 2005 | 08:07 AM
next's Avatar
Phil,
It really looks good. I've fabbed up two kits now and I'll can assure you that you'll always see things everybody else doesn't. There's slight differences in bends that I've made that just jump out and scream at me and I realize I'm the only seeing it.
Kudos on a job well done.
Old Oct 12, 2005 | 08:24 AM
XTrooper's Avatar
Looks very cool!
I'm curious though, is there any particular reason why you decided to go with hard lines as opposed to braided? Is there some advantage?
Seems it would be one hell of a lot easier to use braided lines on a direct port setup.
Old Oct 12, 2005 | 08:44 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
You could bend ever tube the same put on the intake and they will look different.. Think about it this way.. To be perfect which it can not, you would have to have ever nozzle the same depth, ever nozzle fitting the same depth, nozzle install on the same angle(that one is pretty easy with a mill), ever nozzle rotated the same. Ans then all that and now on the rail side also..
Man looks killer to me.
Ricky
Old Oct 12, 2005 | 10:26 AM
Airwolf's Avatar
Phil,
Overall the install looks great. No one is going to point and say "hey that one line is slightly different then that one". No one. When the manifold is in the car the overall effect will blind everyone to any imperfections you yourself see. Trust me. I look at mine and say the same things, that I should have bent a line differently or something, but when I show the car EVERYONE just freaks and they will do the same with yours. Trust me.
From what I see on your install is MUCH more work then my set up. Having the rails does seem to be a bigger pain to setup. More drilling and tapping as well as the polishing...Wow. I like the look though. Keep up the good, no wait, great work!
Old Oct 13, 2005 | 06:44 PM
7 Second Club
Old Oct 13, 2005 | 06:54 PM
lookin good phil.
Old Oct 13, 2005 | 07:34 PM
gollum's Avatar
Braided line will make changing jets a lot easier. But then you would have to fabricate a bracket to hold the twin nitrous/fuel rails stationary.
Some kits are a BITCH to install aren't they. I spent one month just trying to decide where to mount solenoids and route purge line.
Good luck PHIL
Old Oct 13, 2005 | 07:53 PM
69firebird's Avatar
looks good, thats damn nice gonna make a ton of power
Old Oct 13, 2005 | 08:09 PM
CTSmechanic's Avatar
Looks great..kinda of topic but if you want to polish the rails use "Easy off' cleaner on the anodizing it will come off alot easer.... just FYI...
Old Oct 13, 2005 | 08:48 PM
BadAssFast's Avatar
Dave
I admire the work. I wish I had the patience and skill to pull off what you guys can do. Really good stuff...
Old Oct 14, 2005 | 05:11 AM
XTrooper's Avatar
Wire ties are your friend.
I've seen the NX fuel rails simply wire-tied to the stock rails. Fact is, this is exactly what I did with the solenoids on my setup.
Getting back to my original question, am I correct in assuming then that hard lines are used for their aesthetic appeal and not because of some performance advantage over braided ones?
The hard line setups certainly do look cool!
Old Oct 14, 2005 | 05:26 AM
00Vette's Avatar
It looks very nice bro...........good job. Should be a nice piece to look at once you get it all finished up...........
Old Oct 14, 2005 | 08:03 AM
Airwolf's Avatar
The only advantage I see going with hard lines over braided is $$$. And I personally think hard lines look cooler, more old school...
