Nitrous Outlet LS1 Intake System..
Old Nov 3, 2005 | 03:58 PM
  #41
JL ws-6's Avatar
Race your car!
o.k., how about just the elbow then.. so I could just get the intake, and a tb and hook it up for n/a use?
Old Nov 3, 2005 | 04:11 PM
  #42
Nitro Dave's Nitrous Outlet's Avatar
The elbow is 375.00. The spray bars come caped off so if you do not want to spray you can just leave the caps on.
Dave
Old Nov 3, 2005 | 04:26 PM
  #43
383ss's Avatar
can't wait to see some results looks like a good winter mod
Old Nov 3, 2005 | 04:43 PM
  #44
383ss's Avatar
what does it use for gaskets?
Old Nov 3, 2005 | 04:55 PM
  #45
It actually uses the stock gaskets off your LS1 intake.
Dave
Old Nov 3, 2005 | 05:07 PM
  #46
XTrooper's Avatar
Originally Posted by Nitro Dave's Nitrous Outlet
Steve. I do not see any reason why it would not since hood clearence would deffintly not be a issue.
Dave
Sweet! Thanks!
Old Nov 3, 2005 | 08:08 PM
  #47
383ss's Avatar
Dave
kick ***, thanks
are there min/max limits on the N20 stuff?
Old Nov 3, 2005 | 08:11 PM
  #48
Frans96SS's Avatar
does this come with just the upper part of the intake or both parts?
Old Nov 3, 2005 | 08:15 PM
  #49
383ss's Avatar
look at the pricing.
Old Nov 3, 2005 | 10:04 PM
  #50
Frans96SS's Avatar
oh ok i didnt realize the elbow ment the top peice until now
Old Nov 4, 2005 | 10:13 AM
  #51
We sell the unit complete and seperate.
Dave
Old Nov 4, 2005 | 10:14 AM
  #52
Originally Posted by 383ss
kick ***, thanks
WE build it to the customers specs. We will ask the customer how much they are spraying.The spray bars will be set up to fit there needs.
Dave
Old Nov 4, 2005 | 06:58 PM
  #53
Richiec77's Avatar
Super sweet looking set-up. Very nice.
I'm looking into future options now and this piece is great. Takes out the choke point of the Intake.
How stealth is the N2O set-up on the manifold? Not very?
Old Nov 6, 2005 | 08:32 AM
  #54
HartAttack's Avatar
To the top...This is awesome looking.
just waiting for the dyno results... : )
Old Nov 6, 2005 | 08:45 AM
  #55
383ss's Avatar
sorry, more questions.
how bout the MAP sensor? how is it attacthed? I hate the FAST setup for that. can we get a pic of the back?
and I'm assuimg we can get it without the provision for the emissions thing on the driver side front of the intake?
only one suggestion. it would be nice if the elbow BOLTED to the intake instead of welded. I'm not sure if you could go back and port it very easily with it welded on there. and it would just be a little nicer.
looks awesome though.
Old Nov 6, 2005 | 09:22 AM
  #56
Tony Shepherd's Avatar
The elbow does bolt to the intake.
Old Nov 6, 2005 | 09:37 AM
  #57
HartAttack's Avatar
Could a nitrous plate system be used like on carbed cars with this intake..looks like it could imo.
Old Nov 6, 2005 | 10:05 PM
  #58
Sandmann120's Avatar
The only problem with trying to use a plate system is the added clearance needed.
Old Nov 7, 2005 | 09:54 AM
  #59
NXJeremy's Avatar
383ss- The elbow bolts to the intake using the 4 bolt holes on the flange of the intake.
HartAttack- If there was enough room between the top of the elbow and the bottom of the cowl, then yes you could use a carb style nitrous plate. However, I don't think there is enough room for that with this setup.
Old Nov 7, 2005 | 04:26 PM
  #60
n2ojunkie's Avatar
With a intake like this how stealth can you be?
